Updated on 2025-01-20 GMT+08:00
Asset Security Screen
There are always such scenarios as presentation, reporting, or real-time monitoring where you need to present the analysis results of SecMaster on big screens to achieve better demonstration effect. It is not ideal to just zoom in the console. Now, SecMaster Large Screen is a good choice for you to display the service console on bigger screens for a better visual effect.
By default, SecMaster provides an asset screen for you. With this screen, you will learn about overall information about your assets at a glance, including how many assets you have, how many of them have been attacked, and how many of them are unprotected.
You have enabled the large screen module.
Viewing the Asset Security Screen
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Situation > Large Screen.
  5. Click Play in the lower right corner of the asset security image to access the screen.
    This screen includes many graphs. More details are provided below.
Asset Security Screen Overview
On this screen, you can view the total numbers of assets, attacked assets, unprotected assets, vulnerabilities, and assets with unsafe settings in the current workspace.
Table 1 Asset Security Screen
Statistical Period
Update Frequency
Assets
Real-time
Hourly
Total number of assets managed in Resource Manager.
Attacked Assets
Last 7 days
Hourly
Number of assets affected by alerts aggregated in Threat Operations > Alerts in the current workspace.
Unprotected Assets
Real-time
Hourly
Number of assets that are not protected by any security service; for example, ECSs that are not protected by HSS and EIPs that are not protected by DDoS. You will learn of how many assets with Protection Status marked as Unprotected in Resource Manager.
In Resource Manager, the protection status for assets is as follows:
  • Protected: The security product required for an asset is enabled for the asset.
  • Unprotected: The security product required for an asset has not been purchased or enabled for the asset. If you want to protect target assets, purchase corresponding security products and enable protection. For example, if you want to protect ECSs, purchase HSS and enable HSS for each ECS.
  • --: The required security product is not supported in the current region.
Assets with Vulnerabilities or Unsafe Settings
Real-time
Hourly
These assets include assets affected by vulnerabilities and assets have unsafe settings discovered during baseline inspection. The duplicated assets are counted only once.
The vulnerability data comes from the Risk Prevention > Vulnerabilities page, and the baseline inspection data comes from the Risk Prevention > Baseline Inspection > Resources to Check page.
Asset Distribution
In this area, you can view assets by type, asset protection rate, asset change trend, and distribution of the five assets attacked most.
Table 2 Asset Distribution
Statistical Period
Update Frequency
Assets by Type
Real-time
Hourly
Number of different types of assets in Resource Manager.
Protection by Asset Type (%)
Real-time
Hourly
Percentage of protection for different types of assets.
Protection rate of a certain type of assets = Protected assets/Total number of assets of this type.
Asset Changes
Last 7 days
Hourly
Statistics on the total number of assets, and the number of assets with vulnerabilities and unsafe settings in the last seven days.
Top 5 Attacked Assets
Last 7 days
Hourly
Top 5 attacked assets in the last seven days and the number of attacks.
The data comes from Threat Operations > Alerts. You can view details on this page.
Top 5 Assets with the Most Vulnerabilities and Top 5 Departments with the Highest Protection Rate
In this area, you will see the five assets with the most vulnerabilities and the five departments with the highest protection rate.
Table 3 Top 5 Assets with the Most Vulnerabilities and Top 5 Departments with the Highest Protection Rate
Statistical Period
Update Frequency
Real-time
Hourly
Top 5 assets with the most vulnerabilities in different departments.
This data is generated based on the assets affected by vulnerabilities in Risk Prevention > Vulnerabilities. Note that the assets must have department details provided, or the affected assets may fail to be counted toward this data.
Real-time
Hourly
This graph lists the 5 departments that have the highest protection rate, in descending order.
Note that the assets on Resource Manager must have department details provided, or the assets cannot be counted toward this rate.
