Updated on 2025-01-20 GMT+08:00
Importing and Exporting Assets
SecMaster allows you to import assets outside the cloud. After the import, the security status of the assets can be displayed. You can also export asset information.
This section describes how to import and export assets.
Limitations and Constraints
  • Only files in .xlsx can be imported. Each time you can import one file no larger than 5 MB and with a maximum of 100 records.
  • A maximum of 9,999 resource records can be exported.
Importing Assets
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Resource Manager > Resource Manager.
    Figure 2 Resource Manager
  5. On the Resource Manager page, click a tab corresponding to the type of the resources you want to import. For example, if you want to import servers, click the Servers tab.
  6. In the upper left corner of the asset list, click Import.
  7. In the Import dialog box, click Download Template. Then, fill information about the resource to be imported in the template.
  8. After the template is completed, click Select File in the Import dialog box and select the Excel file you want to import.
  9. Click OK.
Exporting Assets
    Figure 3 Workspace management page
    Figure 4 Resource Manager
  5. On the asset management page, click the corresponding asset tab. For example, if you want to export servers, click the Servers tab.
  6. On the asset page, select the assets to be exported and click in the upper right corner of the list.
  7. In the Export dialog box, set asset parameters.
    Table 1 Exporting assets
    Format
    By default, the asset list is exported into an Excel.
    Columns
    Select the parameters to be exported.
  8. Click OK.
    The system automatically downloads the Excel to your local PC.
