Managing Categorical Mappings
This topic describes how to manage categorical mappings, such as enabling, disabling, and deleting a categorical mapping.
- Click in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Objects. On the page displayed, click the Classify&Mapping tab.
Figure 2 Classify&Mapping tab page
- On the Classify&Mapping tab, manage categorical mappings.
Table 1 Managing categorical mappings Operation
Enable
NOTE:Custom categorical mappings cannot be enabled.
Locate the row containing the target categorical mapping and click Disable in the Status column.
If the status changes to Enable, the categorical mapping has been enabled.
Disable
NOTE:Custom categorical mappings cannot be disabled.
Locate the row containing your desired categorical mapping and click Enable in the Status column.
If the status changes to Disable, the categorical mapping has been disabled.
Delete
NOTE:Currently, the built-in categorical mappings cannot be deleted.
- Click Delete in the Operation column of the target categorical mapping.
- In the displayed pane on the right, click Delete.
- If a categorical mapping is deleted, the plug-ins and connections associated with it will be stopped immediately.
- Deleted categorical mappings cannot be restored. Exercise caution when performing this operation.
