Updated on 2025-01-20 GMT+08:00
Managing Vulnerability Types
This section describes how to manage vulnerability types. The detailed operations are as follows:
Limitations and Constraints
  • Currently, the built-in vulnerability types of the system do not support customized layouts.
  • Built-in vulnerability types are enabled by default and cannot be edited, enabled, disabled, or deleted.
  • After a user-defined vulnerability type is added, the type ID cannot be modified.
Viewing Existing Vulnerability Types
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Objects. On the displayed page, click the Type Management tab.
    Figure 2 Type Management page
  5. On the Type Management page, click the Vulnerability Type tab.
  6. On the Vulnerability Type tab page, view details about existing vulnerability types. For details about the parameters, see Table 1.
    Table 1 Vulnerability type parameters
    Type Name/Type Tag
    Name and tag of a vulnerability type
    Associated Layout
    Layout associated with the vulnerability type.
    Startup Status
    Indicates the enabling status of a vulnerability type:
    • Enabled: The current type has been enabled.
    • Disabled: The current type has been disabled.
    Built-in
    Indicates whether the vulnerability is a built-in vulnerability type.
    Description of a vulnerability type
    Operation
    You can edit and delete vulnerability types.
Adding a Vulnerability Type
    Figure 3 Workspace management page
    Figure 4 Type Management page
  6. On the Vulnerability Type page, click Add. On the Add Vulnerability Type slide-out panel, set type parameters.
    Table 2 Vulnerability type parameters
    Type Name
    Name of the vulnerability type to be added.
    Type Tag
    Enter the vulnerability type ID. The keyword must comply with the upper camel case naming rules, for example, TypeTag.
    Startup Status
    Indicates the enabling status of the vulnerability type:
    Description of a user-defined vulnerability
    After a user-defined vulnerability type is added, the Type ID cannot be modified.
  7. In the lower right corner of the page, click Confirm.
    After the threat intelligence type is added, you can view the new type in the table on the Vulnerability Type page.
Associating a Vulnerability Type with a Layout
Currently, built-in vulnerability types do not support customized layouts.
    Figure 5 Workspace management page
    Figure 6 Type Management page
  6. On the Vulnerability Type page, select the vulnerability type to be associated with a layout and click Associated Layout in the Operation column of the target type.
  7. In the Associate Layout dialog box, select the target layout and click OK.
Editing a Vulnerability Type
  • Currently, the built-in vulnerability types cannot be edited.
    Figure 7 Workspace management page
    Figure 8 Type Management page
  6. On the Vulnerability Type page, select the type to be edited and click Edit in the Operation column of the target type.
  7. On the displayed page, edit the parameter information of the corresponding type.
    Table 3 Vulnerability type parameters
    Type Name
    Name of a user-defined vulnerability type
    Type Tag
    Vulnerability type ID, which cannot be modified.
    Startup Status
    Set the enabling status of the vulnerability type:
  8. In the lower right corner of the page, click OK.
Managing a Vulnerability Type
    Figure 9 Workspace management page
    Figure 10 Type Management page
  6. On the vulnerability type tab, manage vulnerability types.
    • Built-in vulnerability types are enabled by default. You do not need to manually enable them.
    • Currently, the built-in vulnerability types cannot be disabled or deleted.
    Table 4 Managing a vulnerability type
    Operation
    Enable
    1. On the Vulnerability Type page, select the type to be enabled and click Batch Enable.
      Alternatively, locate the row containing the vulnerability type to be enabled, click Disable in the Status column.
    2. In the dialog box displayed, click OK.
      If the system displays a message indicating that the operation is successful and the status of the target type changes to Enable, the target type is enabled successfully.
    Disable
    1. On the Vulnerability Type page, select the type to be disabled and click Batch Disable.
      Alternatively, locate the row containing the vulnerability type to be disabled, click Enable in the Status column.
      If the system displays a message indicating that the operation is successful and the Status of the target type changes to Disable, the target type is disabled successfully.
    Delete
    1. On the Vulnerability Type tab, select the vulnerability type to be deleted and click Delete in the Operation column.
    2. In the displayed dialog box, enter DELETE and click OK.
