- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Managing Threat Intelligence Types
This section describes how to manage threat intelligence types.
- Viewing Threat Intelligence Types: describes how to view existing threat intelligence types and their details.
- Adding a Threat Intelligence Type: describes how to create custom threat intelligence types.
- Associating a Threat Intelligence Type with a Layout: describes how to associate a custom threat intelligence type with an existing layout.
- Editing a Threat Intelligence Type: describes how to edit a custom threat intelligence type.
- Managing a Threat Intelligence Type: describes how to enable, disable, and delete a custom threat intelligence type.
Limitations and Constraints
- By default, built-in intelligence types are associated with existing layouts. You cannot customize associated layouts.
- Built-in intelligence types are enabled by default and cannot be edited, enabled, disabled, or deleted.
- After a user-defined threat intelligence type is added, the type ID cannot be modified.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Objects. On the displayed page, click the Type Management tab.
Figure 2 Type Management page
- On the Type Management page, click the Threat Intelligence tab.
- On the Threat Intelligence page, view details. For details about the parameters, see Table 1.
Table 1 Threat intelligence type parameters Parameter
Type Name/Type Tag
Name and type tag of threat intelligence
Associated Layout
Layout associated with threat intelligence
Startup Status
Indicates the enabling status of a threat intelligence type:
- Enabled: The current type has been enabled.
- Disabled: The current type has been disabled.
Expired Time
Expiration time of threat intelligence.
Built-in
Indicates whether the threat intelligence is built in the system.
Description of a threat intelligence
Operation
You can edit and delete the threat intelligence.
- Click
Figure 3 Workspace management page
Figure 4 Type Management page
- On the Threat Intelligence page, click Add. On the Add Threat Intelligence slide-out panel, set type parameters.
Table 2 Threat intelligence type parameters Parameter
Type Name
Name of the threat intelligence to be added.
Type Tag
Enter the threat intelligence type ID. The keyword must comply with the upper camel case naming rules, for example, TypeTag.
Startup Status
Set the enabling status of a threat intelligence.
Expired Time
Set the expiration time of threat intelligence.
- Never Expire: The current intelligence type never expires.
- Time Interval: Set the interval for invalidating intelligence.
Description of a custom threat intelligence
- In the lower right corner of the page, click OK.
After the threat intelligence type is added, you can view the new type in the table on the Threat Intelligence page.
By default, built-in threat intelligence types are associated with existing layouts. You cannot customize associated layouts.
- Click
Figure 5 Workspace management page
Figure 6 Type Management page
- On the Threat Intelligence page, select the type to be associated with a layout and click Associated Layout in the Operation column of the target type. The Associate Layout dialog box is displayed.
- In the Associate Layout dialog box, select the target layout and click OK.
- Currently, built-in threat intelligence types cannot be edited.
- After a custom threat intelligence type is added, the type tag cannot be edited.
- Click
Figure 7 Workspace management page
Figure 8 Type Management page
- On the Threat Intelligence page, select the type to be edited and click Edit in the Operation column of the target type. The editing page is displayed on the right.
- On the displayed page, edit the parameter information of the corresponding type.
Table 3 Threat intelligence type parameters Parameter
Type Name
Name of the user-defined threat intelligence type.
Type Tag
Threat intelligence type ID, which cannot be modified.
Startup Status
Indicates the enabling status of threat intelligence:
Expired Time
- Never expire: The current intelligence type never expires.
- Interval: Set the interval for intelligence type expiration.
Description of a custom threat intelligence type
- In the lower right corner of the page, click Confirm.
- Click
Figure 9 Workspace management page
Figure 10 Type Management page
- On the threat intelligence type tab, manage threat intelligence types.
- Built-in threat intelligence types are enabled by default. You do not need to manually enable them.
- Currently, built-in threat intelligence types cannot be disabled or deleted.
Table 4 Managing a threat intelligence type Operation
Enable
- On the Threat Intelligence page, select the types to be enabled and click Batch enable in the upper left corner of the type list.
Alternatively, locate the row containing the threat intelligence to be enabled, click Disable in the Status column.
- In the dialog box displayed, click OK.
If the system displays a message indicating that the operation is successful and the status of the target type changes to Enable, the target type is enabled successfully.
Disable
- On the Threat Intelligence page, select the types to be disabled and click Batch Disable in the upper left corner of the type list.
Alternatively, locate the row containing the threat intelligence to be disabled, click Enable in the Status column.
If the system displays a message indicating that the operation is successful and the Status of the target type changes to Disable, the target type is disabled successfully.
Delete
- On the threat intelligence type management tab, select the type to be deleted and click Delete in the Operation column.
- In the displayed dialog box, enter DELETE and click OK.
