Managing Incident Types
Updated on 2025-01-20 GMT+08:00
This section describes how to manage incident types. The detailed operations are as follows:
Limitations and Constraints
  • By default, built-in incident types are associated with existing layouts. You cannot customize associated layouts.
  • Built-in incident types are enabled by default and cannot be edited, enabled, disabled, or deleted.
  • After a customized incident type is added, the Type Name, Type ID, and Subtype ID parameters cannot be modified.
Viewing Incident Types
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Orchestration > Objects. On the displayed page, click the Type Management tab.
    Figure 2 Type Management page
  5. On the Type Management page, click the Event Types tab.
  6. On the Event Types tab, view the details about existing incident types. For details about the parameters, see Table 1.
    Table 1 Incident type parameters
    Type Name
    Name of an incident type
    Sub Type/Sub Type Tag
    Name and ID of an incident subtype
    Associated Layout
    Layout associated with the incident type
    Startup Status
    Indicates whether an incident type is enabled.
    • Enable: The current type has been enabled.
    • Disabled: The current type has been disabled.
    SLA
    SLA processing time of an incident type
    Description of an incident type
    Operation
    You can edit and delete incident types.
Adding an Incident Type
    Figure 3 Workspace management page
    Figure 4 Type Management page
  6. On the Event Types tab, click Add. On the Add Event Type slide-out panel, set incident type parameters.
    Table 2 Incident type parameters
    Type Name
    Customized name of an incident type.
    Type Tag
    Enter the incident type ID. The keyword must comply with the upper camel case naming rules, for example, TypeTag.
    Sub Type
    Enter the subtype of the incident type.
    Sub Type Tag
    Enter the incident subtype ID. The keyword must comply with the upper camel case naming rules, for example, SubTypeName.
    Startup Status
    SLA
    Set the SLA processing time of the incident.
    Description of a custom incident type
  7. In the lower right corner of the page, click OK.
    After the incident type is added, you can view the new incident type in Type Name on the Event Type page.
Associating an Incident Type with a Layout
    Figure 5 Workspace management page
    Figure 6 Type Management page
  6. On the Event Type page, select the incident type to be associated with a layout and click Associated Layout in the Operation column of the target type.
  7. In the Associate Layout dialog box, select the target layout and click OK.
Editing an Incident Type
  • Currently, the built-in incident type cannot be edited.
    Figure 7 Workspace management page
    Figure 8 Type Management page
  6. In Type Name on the Alarm Types page, click the name of the customized incident type to be edited. Details about the custom incident type are displayed on the right.
  7. On the Event Type page, click Edit in the Operation column of the target type to be edited.
  8. In the Edit Event Type dialog box, edit parameters.
    Table 3 Incident type parameters
    Type Name
    Name of an incident type, which cannot be modified.
    Type Tag
    Incident type ID, which cannot be modified.
    Sub Type
    Sub Type Tag
    Incident subtype ID, which cannot be modified.
    Startup Status
    SLA
  9. In the lower right corner of the page, click OK.
Managing Existing Incident Types
    Figure 9 Workspace management page
    Figure 10 Type Management page
  6. On the incident type tab, manage incident types.
    • The built-in incident types are enabled by default. You do not need to manually enable them.
    • Currently, built-in incident (event) types cannot be disabled or deleted.
    Table 4 Managing existing incident types
    Operation
    Enable
    1. On the type management page, select the type to be enabled and click Batch Enable.
      Alternatively, locate the row containing the incident type to be enabled, click Disable in the Status column.
    2. In the dialog box displayed, click OK.
      If the system displays a message indicating that the operation is successful and the status of the target type changes to Enable, the target type is enabled successfully.
    Disable
    1. On the Event Type page, select the type to be disabled and click Batch Disable.
      Alternatively, locate the row containing the incident type to be disabled, click Enable in the Status column.
      If the system displays a message indicating that the operation is successful and the Status of the target type changes to Disable, the target type is disabled successfully.
    Delete
    1. On the incident type management page, select the type to be deleted and click Delete in the Operation column.
    2. In the displayed dialog box, enter DELETE and click OK.
