- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Adding and Editing an Incident
This section describes how to add or edit an incident.
Adding an Incident
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Threat Operations > Incidents.
Figure 2 Incidents
- On the Incidents page, click Add. On the displayed Add page, set parameters as described in Table 1.
Table 1 Parameters for adding an incident Parameter
Basic Information
Incident Name
Custom incident name. The value must contain:
- Only uppercase letters, lowercase letters, digits, and the special characters: -_ ()
- A maximum of 2,550 characters
Type
Incident type
(Optional) Service ID
Enter the service ID corresponding to the incident.
Incident Severity
Select a severity level.
Status
Select an incident status.
(Optional) Owner
Primary owner of the incident.
Data Source Product Name
Select the name of the data source product.
Data Source Type
Select the type of the data source. For example, if the data source is a cloud service, select the cloud service.
Timeline
First Occurrence Time
Time when the incident occurred first time.
(Optional) Last Occurrence Time
Time when the incident occurred last time.
(Optional) Planned Closure Time
Time to close the incident.
Other
(Optional) Verification Status
Verification status of the incident to identify the accuracy of the incident.
(Optional) Stage
Incident phase.
- Preparation: Prepare resources to process incidents.
- Detection and analysis: Detect and analyze the cause of an incident.
- Containment, extradition, and recovery: Handle an incident.
- Post Incident Activity: Follow-up activities.
(Optional) Debugging data
Whether to enable simulated debugging
(Optional) Labels
Label of the incident.
Incident description. The value can contain:
- A maximum of 10,240 characters.
- Click OK. The incident is created.
Editing an Incident
- Click
Figure 3 Workspace management page
Figure 4 Incidents
- In the incident list, locate the row that contains the target incident and click Edit in the Operation column.
- On the Edit page that is displayed, edit incident parameters.
Table 2 Parameters for editing an incident Parameter
Basic Information
Incident Name
Incident Type
Incident type
Incident Level
Status
(Optional) Owner
Data Source Name
Name of the data source, which cannot be changed
Data Source Type
Type of the data source, which cannot be changed
Timeline
Other
(Optional) Phase
Incident phase.
- Contain, extradition, and recovery: Handle an incident.
Whether to enable simulated debugging. This parameter cannot be modified once configured.
(Optional) Label
- Click OK. The incident editing is complete.
