Converting an Alert into an Incident or Associating an Alert with an Incident
SecMaster analyzes alerts it aggregates from other services. During the analysis, if SecMaster detects attacks or serious threats, it converts such alerts into incidents or associates such alerts with certain incidents.
This section describes how to convert an alert into an incident and how to associate an alert with an incident.
Relationships Between Alerts and Incidents
This part describes the meanings and differences between alerts and incidents, reasons for converting alerts into incidents, and reasons for associating alerts with incidents.
- Meanings and Differences Between Alerts and Incidents
- Causes for converting alerts into incidents or associating alerts with incidents
An alert is a notification generated when a system or service becomes abnormal or a potential fault occurs. These exceptions may directly affect service availability. So alerts must be handled in a timely manner to prevent service exceptions. When an alert is generated, you need to take corresponding measures to rectify the fault. Otherwise, services may be abnormal due to these exceptions or faults.
An incident is a notification generated when the system or service is running properly. An event may involve some important status changes, but may not cause service exceptions. So incidents do not need to be handled. They are mainly used to analyze and locate problems.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
.Figure 2 Alerts
- In the alert list, locate the row that contains the target alert, click Convert to Incident in the Operation column. The Convert to Incident page is displayed on the right.
In addition, you can click Alert-to-Incident in the upper right corner of the details page of an alarm.
- On the Convert to Incident page, specify Incident Name and Type.
The incident name is automatically set to the name of the current alert. This name can be modified.
- Click OK.
- Click
Figure 3 Workspace management page
.Figure 4 Alerts
- In the alert list, select the alerts you want to associate and click Associated Event above the list. The Bind Incident dialog box is displayed.
- In the dialog box displayed, select the target incidents and click OK.
After the association is complete, click the type of the target alert in the alert list. On the alert details page displayed, choose
and check the association details.
