Updated on 2025-01-20 GMT+08:00
Workspace Overview
This topic describes the following details about workspaces:
Actions you can do:
- Creating a Workspace: Workspaces are top-level operation platform in SecMaster. A workspace can be associated with general projects and enterprise projects to meet different security operations needs. Before using baseline inspection, alert management, security analysis, and security orchestration in SecMaster, you need to create at least one workspace first. You can use workspaces to group your resources by application scenario. This will make security operations more efficient.
- Viewing a Workspace: You can view the details about a workspace, including its name, type, and creation time.
- Editing a Workspace: You can modify the workspace basic settings, including its name and description.
- Deleting a Workspace: If you no longer need a workspace, you can delete it. After a workspace is deleted, SecMaster may be unable to detect security risks of assets managed in the workspace. So the risk of those assets may fail to be prevented. Deleted workspaces cannot be restored. Exercise caution when performing this operation.
- Managing Workspace Tags: After creating a workspace, you can add, edit, and delete tags configured for the workspace. A tag consists of a key-value pair. Tags are used to identify, and classify workspaces. Workspace tags are used for workspace management only.
Parent topic: Workspaces
