- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Product Advantages
Refined Indicators and Intuitive Situation Display
You can view the security overview on the large screen in real time and periodically subscribe to security operation reports to know the core security indicators.
Cloud Native Asset Stocktaking and Risk Prevention
All assets and security configurations on the cloud are automatically checked, and automatic hardening is provided to help you fix risky assets and insecure configurations. This avoids implicit channels and security device vulnerabilities introduced by traditional bolted-on security solutions.
Intelligent and Efficient Threat Detection, Response, and Handling
SecMaster focuses on finding true threats. By analyzing billions of security logs daily and leveraging the years of experience accumulated, SecMaster utilizes built-in models and analysis playbooks to reduce the interference from normal incidents. Threat and asset security profiling enables restoration of the entire attack chain. Risk handling playbooks can be configured for automatic response, simplifying operations and improving security and efficiency.
Environment Integration and Operational Collaboration for Ultimate Flexibility
You can connect to all security products, devices, and tools to connect data and operations (Bidirectional interconnection is supported). You can also define your own response models and analysis/handling playbooks to best meet your security requirements. You can use workspaces to enable large-scale organization collaboration and MSSP (Managed Security Service Provider) services.
