Updated on 2025-01-20 GMT+08:00
Handling a To-Do Task
When a playbook or process task reaches a node, the task needs to be suspended manually so that the playbook or process task can continue.
Process to-do tasks.
A playbook task has been triggered, and manual actions are required for completing the task.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Security Situation > Task Center.
    Figure 2 To-Dos
  5. In the row containing the target to-do task, click Approve in the Operation column.
    The approval mode varies according to the service type.
    • Playbook release: The Playbook Release page is displayed on the right. Enter review comments and approve the playbook as prompted.
    • Process release: The Process Release page is displayed on the right. Enter the Comment and approve the application as prompted.
    • Playbook-Node Review: The Playbook-Node Review page is displayed on the right. You can select Continue or Terminate.
