- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- How Is SecMaster Billed?
- Can I Use SecMaster for Free?
- How Do I Change or Disable Auto Renewal for SecMaster?
- Will SecMaster Be Billed After It Expires?
- How Do I Renew SecMaster?
- Where Can I Unsubscribe from SecMaster?
- Where Can I View the Remaining Quotas of Security Data Collection and Security Data Packages?
- Can I Change the Billing Mode for SecMaster?
- Getting Started
User Guide
- Buying SecMaster
- Authorizing SecMaster
- Checking Security Overview
- Workspaces
- Viewing Purchased Resources
Security Governance
- Security Governance Overview
- Security Compliance Pack Description
- Authorizing SecMaster to Access Cloud Service Resources
- Subscribing to or Unsubscribing from a Compliance Pack
- Starting a Self-Assessment
- Viewing Security Compliance Overview
- Viewing Evaluation Results
- Viewing Policy Scanning Results
- Downloading a Compliance Report
- Security Situation
- Resource Manager
- Risk Prevention
- Threats
- Security Orchestration
Playbook Overview
- Ransomware Incident Response Solution
- Attack Link Analysis Alert Notification
- HSS Isolation and Killing of Malware
- Automatic Renaming of Alert Names
- Auto High-Risk Vulnerability Notification
- Automatic Notification of High-Risk Alerts
- Auto Blocking for High-risk Alerts
- Real-time Notification of Critical Organization and Management Operations
Settings
- Data Integration
Log Data Collection
- Data Collection Overview
- Data Collection Process
- Adding a Node
- Configuring a Component
- Adding a Connection
- Creating and Editing a Parser
- Adding and Editing a Collection Channel
- Verifying Log Collection
- Managing Connections
- Managing Parsers
- Managing Collection Channels
- Viewing Collection Nodes
- Managing Nodes and Components
- Partitioning a Disk
- Logstash Configuration Description
- Connector Rules
- Parser Rules
- Upgrading the Component Controller
- Customizing Directories
- Permissions Management
- Key Operations Recorded by CTS
Best Practices
Log Access and Transfer Operation Guide
- Solution Overview
- Resource Planning
- Process Flow
- (Optional) Step 1: Buy an ECS
- (Optional) Step 2: Buy a Data Disk
- (Optional) Step 3: Attach a Data Disk
- Step 4: Create a Non-administrator IAM User
- Step 5: Configure Network Connection
- Step 6: Install the Component Controller (isap-agent)
- Step 7: Install the Log Collection Component (Logstash)
- (Optional) Step 8: Creating a Log Storage Pipeline
- Step 9: Configure a Connector
- (Optional) Step 10: Configure a Log Parser
- Step 11: Configure a Log Collection Channel
- Step 12: Verify Log Access and Transfer
- Credential Leakage Response Solution
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Alert Management
- Incident Management
- Indicator Management
- Playbook Management
- Alert Rule Management
- Playbook Version Management
- Playbook Rule Management
- Playbook Instance Management
- Playbook Approval Management
- Playbook Action Management
- Incident Relationship Management
- Data Class Management
- Workflow Management
- Data Space Management
- Pipelines
- Workspace Management
- Metering and Billing
- Metric Query
- Baseline Inspection
- Appendix
- FAQs
More Documents
- Buying SecMaster
- Viewing Security Overview
- Workspaces
Security Governance
- Resource Manager
- Risk Prevention
- Threat Operations
Settings
- Data Integration
Log Data Collection
- Adding a Node
- Managing Parsers
- Connector Rules
- Parser Rules
- FAQs
- Change History
- Security Overview
- Workspaces
- Resource Manager
Risk Prevention
Baseline Inspection
- Baseline Inspection Overview
- Creating a Custom Check Plan
- Starting an Immediate Baseline Check
- Viewing Check Results
- Handling Check Results
- Viewing Compliance Packs
- Creating a Custom Compliance Pack
- Importing and Exporting a Compliance Pack
- Viewing Check Items
- Creating a Custom Check Item
- Importing and Exporting Check Items
- Vulnerability Management
- Policy Management
Baseline Inspection
Threat Operations
- Alert Management
- Intelligent Modeling
- Security Analysis
- Data Delivery
- Security Orchestration Overview
- Built-in Playbooks
- Security Orchestration Process
- (Optional) Configuring and Enabling a Workflow
- Configuring and Enabling a Playbook
- Operation Object Management
- Playbook Orchestration Management
- Layout Management
- Plug-in Management
- Settings
Product Consulting
- Why Is There No Attack Data or Only A Small Amount of Attack Data?
- Where Does SecMaster Obtain Its Data From?
- What Are the Dependencies and Differences Between SecMaster and Other Security Services?
- What Are the Differences Between SecMaster and HSS?
- How Do I Update My Security Score?
- How Do I Handle a Brute-force Attack?
- Issues About Data Synchronization and Data Consistency
- About Data Collection Faults
Product Consulting
- Change History
Managing Asset Connections
- Definition: An asset connection consists of the domain name and authentication parameters required by each plug-in node set during the security orchestration process.
- Function: During security orchestration, each plug-in node transfers the domain name to be connected and the authentication information, such as the username, password, and account AK/SK, to establish connections.
- Relationship between asset connections and plug-ins: Plug-ins access other cloud services or third-party services through domain names and authentication. So, domain name parameters (endpoints) and authentication parameters (username/password, account AK/SK, etc.) are defined in the login credential parameters of plug-ins. An asset connection configures login credential parameters for a plug-in. In a workflow, each plug-in node is associated with different asset connections so that the plug-in can access different services.
This topic describes how to manage asset connections, including Adding an Asset Connection, Viewing Asset Connections, Editing an Asset Connection, and Deleting an Asset Connection.
- Click
in the upper part of the page and choose Security > SecMaster.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
Figure 1 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. On the displayed page, click the Asset Connections tab.
Figure 2 Asset Connections tab
- On the Asset Connections tab page, click Add. The slide-out panel Add is displayed on the right.
- On the panel, set asset connection parameters. For details about the parameters, see Table 1.
Table 1 Asset connection parameters Parameter
Connection Name
Enter the asset connection name. The naming rules are as follows:
- Only uppercase letters (A to Z), lowercase letters (a to z), digits (0 to 9), and underscores (_) are allowed.
- A maximum of 64 characters are allowed.
(Optional) Enter the asset description. The description can contain a maximum of 64 characters.
Plug In
Select the plug-in required for the asset connection. For details about the plug-in, see Viewing Plug-in Details.
Connection Type
Select the type of the asset connection.
- Cloud service agency: If a cloud service plug-in is used, the cloud service agency is recommended.
You do not need to manually enter authentication parameters such as the domain name, username, and password. The system automatically obtains the domain name (endpoint) of the corresponding cloud service based on the plug-in name and uses the cloud service agency for authentication.
- AK&SK: You need to manually enter the domain name (endpoint) and provide an AK and SK for authentication.
- Username and password: You need to manually enter the domain name (endpoint) and provide a username and password for authentication.
- Others: Some plug-ins have other authentication parameters in addition to the preceding authentication parameters. Set these parameters based on the plug-in login credential parameter guide.
Credential
Enter the credential information, such as the endpoint, AK, and SK, based on the selected connection type.
- Click OK. You can query the created asset connection in the asset connection list.
- Click
Figure 3 Workspace management page
Figure 4 Asset Connections tab
- On the Asset Connections tab page, view information about asset connections.
Figure 5 Viewing asset connections
- In the asset connection list, you can view the name, plug-in, and creator of an asset connection.
- If there are many asset connections displayed, use filters to search for a specific one.
- To view details about an asset connection, click its name to go to its Detail panel.
- Click
Figure 6 Workspace management page
Figure 7 Asset Connections tab
- In the row containing a desired asset connection, click Edit in the Operation column. The slide-out panel Edit is displayed.
- On the Edit panel, edit asset connection parameters. For details about the parameters, see Table 2.
Table 2 Asset connection parameters Parameter
Connection Name
(Optional) Enter the asset connection description. The description can contain a maximum of 64 characters.
Plug In
Select the plug-in required for the asset connection. For details about plug-ins, see Viewing Plug-in Details.
Created By
The creator of the asset connection. This parameter cannot be modified.
Created
Time when the asset connection is created. This parameter cannot be modified.
Modified By
The user who last modifies the asset connection. This parameter cannot be modified.
Connection Type
Credential
Enter the credential information, such as AK and SK, based on the selected connection type.
- Click OK.
- Click
Figure 8 Workspace management page
Figure 9 Asset Connections tab
- Locate the row that contains a desired asset connection, click Delete in the Operation column.
- In the confirmation dialog box, enter DELETE and click OK.
Deleted assets cannot be restored. Exercise caution when performing this operation.
