Performing a Scheduled Baseline Check
Updated on 2025-01-20 GMT+08:00
SecMaster can check whether your assets have risks based on baseline check plans. By default, every three days SecMaster automatically performs a baseline check on all assets in the current region under your account from 00:00 to 06:00 in accordance with compliance pack Cloud Security Compliance Check 1.0. This function is enabled by default. So there are no manual actions required.
You can customize the automatic inspection period, time, and scope to create custom check plans.
This document describes how to create a custom baseline check plan.
Limitations and Constraints
  • A compliance pack can be added to only one check plan.
  • SecMaster cannot execute check plans that include manual check items. So do not add compliance packs that include manual check items to a check plan. There are manual check items in DJCP 2.0 Level 3 Requirements.
  • The default check plan can be enabled or disabled only. No changes on its compliance packs or execution time can be made.
  2. Click in the upper part of the page and choose Security > SecMaster.
  3. In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace.
    Figure 1 Workspace management page
  4. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the displayed page, click the Security Standards tab. Then, click the Check Plan tab.
    Figure 2 Check Plan tab
  5. On the Check Plan tab, click Create Plan. The pane for creating a plan is displayed on the right.
  6. Configure the check plan.
    Table 1 Parameters for creating a check plan
    Basic Information
    Name
    Custom plan name.
    Schedule
    Select how often and when the check plan is executed.
    • Schedule: every day, every 3 days, every 7 days, every 15 days, or every 30 days
    • Check start time: 00:00-06:00, 06:00-12:00, 12:00-18:00, or 18:00-24:00
    Select Compliance Pack
    Select the compliance pack you want to use.
  7. Click OK.
    After the check plan is created, SecMaster performs cloud service baseline scanning at the specified time. You can choose Risk Prevention > Baseline Inspection to view the scan result.
Related Operations
You can view, edit, enable, disable, or delete a custom check plan.
  • Viewing a check plan
    1. In the navigation pane on the left, choose Risk Prevention > Baseline Inspection. On the Baseline Inspection page, click the Security Standards tab. Then, click the Check Plan tab.
    2. On the Check Plan page, view what check plans you already have.
  • Editing a custom check plan
    Only custom check plans can be edited.
    2. In the upper right corner of the check plan box, click Edit. The pane for editing the check plan is displayed on the right.
    3. Edit settings and click OK.
  • Deleting a custom check plan
    Only custom check plans can be deleted.
    2. In the upper right corner of the check plan box, click Delete.
    3. In the displayed dialog box, click OK.
  • Disabling or enabling a check plan
    2. Toggle on or off the status button in the box where the target plan is located.
