- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
RabbitMQ Metrics
Introduction
This section describes metrics reported by DMS for RabbitMQ to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console to query the metrics and alarms of RabbitMQ instances. You can also view the metrics on the Monitoring page of the RabbitMQ console.
Namespace
SYS.DMS
Instance Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
Monitoring Period (Raw Data) |
connections |
Connections |
Number of connections in the RabbitMQ instance Unit: Count |
≥ 0 |
RabbitMQ instance |
1 minute |
channels |
Channels |
Number of channels in the RabbitMQ instance Unit: Count |
0–2047 |
RabbitMQ instance |
1 minute |
queues |
Queues |
Number of queues in the RabbitMQ instance Unit: Count |
0–7,000 |
RabbitMQ instance |
1 minute |
consumers |
Consumers |
Number of consumers in the RabbitMQ instance Unit: Count |
0–280,000 |
RabbitMQ instance |
1 minute |
messages_ready |
Available Messages |
Number of messages that can be consumed in the RabbitMQ instance Unit: Count |
0–10,000,000 |
RabbitMQ instance |
1 minute |
messages_unacknowledged |
Unacknowledged Messages |
Total number of messages that have been consumed but not acknowledged in a RabbitMQ instance Unit: Count |
0–10,000,000 |
RabbitMQ instance |
1 minute |
publish |
Message Creation Rate |
Rate at which messages are produced in the RabbitMQ instance Unit: Count/second |
0–25,000 |
RabbitMQ instance |
1 minute |
deliver |
Retrieval Rate (Manual Ack) |
Rate at which messages are consumed (in the manual acknowledgment scenario) in a RabbitMQ instance Unit: Count/second |
0–25,000 |
RabbitMQ instance |
1 minute |
deliver_no_ack |
Retrieval Rate (Auto Ack) |
Rate at which messages are consumed (in the automatic acknowledgment scenario) in a RabbitMQ instance Unit: Count/second |
0–50,000 |
RabbitMQ instance |
1 minute |
Broker Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
fd_used |
File Handles |
Number of file handles used by RabbitMQ in the node Unit: Count |
0–65,535 |
RabbitMQ instance node |
1 minute |
socket_used |
Socket Connections |
Number of socket connections used by RabbitMQ in the node Unit: Count |
0–50,000 |
1 minute |
proc_used |
Erlang Processes |
Number of Erlang processes used by RabbitMQ in the node Unit: Count |
0–1,048,576 |
1 minute |
mem_used |
Memory Usage |
Memory usage of RabbitMQ in the node Unit: byte, KB, MB, GB, TB or PB |
0–32,000,000,000 |
1 minute |
disk_free |
Available Memory |
Available memory of RabbitMQ in the node Unit: byte, KB, MB, GB, TB or PB |
0–500,000,000,000 |
1 minute |
Queue Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object |
queue_messages_unacknowledged |
Number of messages that have been consumed but not acknowledged in the RabbitMQ queue Unit: Count |
0–10,000,000 |
RabbitMQ instance queue |
1 minute |
queue_messages_ready |
Number of messages that can be retrieved in a RabbitMQ queue Unit: Count |
0–10,000,000 |
1 minute |
Dimensions
Key |
Value |
rabbitmq_instance_id |
RabbitMQ instance |
rabbitmq_node |
rabbitmq_queue |
