- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
There are two scenarios for migrating RabbitMQ services:
- Single-node or cluster RabbitMQ instances can be migrated from on-premises to on-cloud RabbitMQ instances.
- An earlier RabbitMQ instance can be migrated to a later one, for example, from 3.7.17 to 3.8.35.
Migration Principle
A RabbitMQ instance has multiple producers and consumers. To migrate services, add and remove them one by one without altering data. This process has no impact on services.
Prerequisite
A target RabbitMQ instance has been created. For details, see Buying a RabbitMQ Instance.
Implementation (Dual-Read)
- Migrate source RabbitMQ instance metadata to a target RabbitMQ instance.
Figure 1 Migrating metadata
Do as follows:
- Log in to the management UI of the source RabbitMQ. On the Overview tab page, click Download broker definitions to export the metadata.
Figure 2 Exporting metadata
- Log in to the management UI of the target RabbitMQ. On the Overview tab page, click Choose File and select the metadata exported in 1.a, and click Upload broker definitions to upload the metadata.
Figure 3 Importing metadata
- Add new consumers for the target RabbitMQ instance.
Figure 4 Adding new consumers
- Add new producers for the target RabbitMQ instance and remove the producers of the source RabbitMQ instance. The old consumers continue consuming messages from the source RabbitMQ instance.
Figure 5 Migrating producers
- After the old consumers have consumed all messages from the source RabbitMQ instance, remove them along with the source RabbitMQ instance.
Figure 6 Removing an old consumer and a source RabbitMQ instance
Check After Migration
Check whether the consumption from the source instance is complete in either of the following ways:
- Using the RabbitMQ management UI, as shown in Figure 7.
On the Overview tab page, if the number of messages that can be consumed (Ready) and the number of messages that are not acknowledged (Unacked) are both 0, the consumption is complete.
- Calling an API
curl -s -u username:password -XGET http://ip:port/api/overview
Parameter description:
- username: account of the source instance to log in to the RabbitMQ management UI
- password: password of the source instance to log in to the RabbitMQ management UI
- ip: IP address of the source instance to log in to the RabbitMQ management UI
- port: port of the source instance to log in to the RabbitMQ management UI
The consumption is complete when messages_ready and messages_unacknowledged values in the command output are both 0.
Figure 8 Command output
