Assigning Dependency Roles
Cloud services interwork with each other. Roles of some services take effect only if they are assigned along with roles of other services.
- When assigning permissions to users or user groups, search for a role in the search box.
- Select the target role. The system automatically selects the dependency roles.
Figure 1 Selecting a role
- Click
next to the role to view the dependencies.
Figure 2 Viewing dependencies
For example, the DNS Administrator role contains the Depends parameter which specifies the dependency roles. When you assign the DNS Administrator role to a user group, you also need to assign the Tenant Guest and VPC Administrator roles to the group for the same project.
- Click OK.
