- What's New
- Function Overview
- Billing
Getting Started
- Creating a Function from Scratch and Executing the Function
- Creating a Function Using a Template and Executing the Function
- Creating an HTTP Function Using a Container Image and Executing the Function
- Creating an Event Function Using a Container Image and Executing the Function
- Getting Started with Common Practices
User Guide
- Replacing the Temporary AK/SK
- Before You Start
- Building Functions
Configuring Functions
- Configuring Initialization
- Configuring Basic Settings
- Configuring Agency Permissions
- Configuring the Network
- Configuring Disk Mounting
- Configuring Environment Variables
- Configuring Asynchronous Execution Notification
- Configuring Single-Instance Multi-Concurrency
- Managing Versions
- Managing Aliases
- Configuring Dynamic Memory
- Configuring Heartbeat Function
- Configuring Tags
- Configuring Snapshot-based Cold Start
- Configuring a Log Group and Log Stream
- Stateful Functions
- Shared VPC
- Online Debugging
Creating Triggers
- Managing Triggers
- Using a Timer Trigger
- Using an APIG (Dedicated) Trigger
- Using a Kafka Trigger
- Using a DIS Trigger
- Using an SMN Trigger
- Using an LTS Trigger
- Using a CTS Trigger
- Using a DDS Trigger
- Using a GeminiDB Mongo Trigger
- Using an APIG Trigger
- Using an APIC Trigger
- Using a DMS (for RabbitMQ) Trigger
- Using an Open-Source Kafka Trigger
- Cron Expressions for a Function Timer Trigger
- Using an EG Trigger
- Invoking the Function
- Monitoring
- Function Management
- Dependency Management
- Reserved Instance Management (Old)
- Flow Management
- Increasing Resource Quota
- GPU Function Management
- Application Center
- Sharing
- Programmable CDN Function
- CLI Command Reference
- Audit
Best Practices
- FunctionGraph Best Practices
- Processing DIS Data
- Integrating with LTS to Analyze Logs in Real Time
- Integrating with CTS to Analyze Login/Logout Security
- Periodically Starting or Stopping Huawei Cloud ECSs
- Building an HTTP Function with Spring Boot
- Creating a FunctionGraph Backend API That Uses a Custom Authorizer
- Uploading Files with FunctionGraph and APIG
- Processing IoT Data
- Workflow + Function: Automatically Processing Data in OBS
- Filtering Logs in Real Time by Using FunctionGraph and LTS
- Deploying AI Drawing Stable-Diffusion in the Application Center
- Building an HTTP Function with Go
- Using FunctionGraph HTTP Functions to Process gRPC Requests
- Cold Start Optimization Practices
Developer Guide
- Overview
- Initializer
- Node.js
- Python
- Java
- Go
- C#
- PHP
- Development Tools
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
- Extension and OpenTelemetry APIs
APIs
- Function Invocation
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
Function Lifecycle Management
- Querying Functions
- Deleting a Function or Function Version
- Querying the Code of a Function
- Modifying the Code of a Function
- Querying the Metadata of a Function
- Modifying the Metadata of a Function
- Updating Max. Instances of a Function
- Querying Function Tags
- Enabling or Disabling the Snapshot Function
- Querying ServiceBridge Functions Bound to a Specified Function
- Querying Snapshot Status
- Querying Resource Tags
- Querying Resources
- Deleting Resource Tags
- Creating Resource Tags
- Creating a VPC Endpoint
- Deleting a VPC Endpoint
- Updating the Pinning Status of a Function
- Querying the Available ServiceBridge Version
- Versions and Aliases
- Function Metrics
- Function Logs
- Function Templates
- Reserved Instances
- Function Import and Export
- Function Triggers
Function Flows
- Executing a Flow Synchronously
- Executing a Flow Asynchronously
- Deleting Flows
- Querying a Flow
- Creating a Flow
- Querying Instances of a Flow
- Querying a Flow Instance
- Querying Metadata of a Flow Instance
- Modifying Metadata of a Flow Instance
- Querying Flow Metrics
- Querying Metrics of a Flow
- Re-executing a Flow
- Stopping a Flow
- Querying Records of a Flow in Pagination Mode
- Calling Back a Flow
- Querying Asynchronous Execution Notification Settings of a Function Version
- Deleting Asynchronous Execution Notification Settings
- Querying Asynchronous Execution Notification Settings of a Function's All Versions
- Querying Asynchronous Invocation Requests
- Querying Active Asynchronous Invocation Requests
- Stopping an Asynchronous Invocation Request
- Appendix
- Change History
- SDK Reference
General FAQs
- What Is FunctionGraph?
- Do I Need to Apply for Any Compute, Storage, or Network Services When Using FunctionGraph?
- Do I Need to Deploy My Code After Programming?
- How Do I Obtain a Token?
- What Runtimes Does FunctionGraph Support?
- How Much Disk Space Is Allocated to Each FunctionGraph Function?
- Does FunctionGraph Support Function Versioning?
- How Does a Function Read or Write Files?
- How Do I Set a Proxy When Using CLI?
- Does FunctionGraph Support Function Extension?
- Which Permissions Are Required for an IAM User to Use FunctionGraph?
- How Can I Create an ODBC Drive-based Python Dependency Package for Database Query?
- What Is the Quota of FunctionGraph?
- What Chinese Fonts Does FunctionGraph Support?
- How Does FunctionGraph Resolve a Private DNS Domain Name?
- How Does a Container Image–based Function Resolve a Private DNS Domain Name?
- How Do I Use a Domain Name to Access an API Registered with API Gateway (Dedicated)?
- What Are the Common Application Scenarios of FunctionGraph?
- Why Can't the API Gateway Domain Name Bound to a Service Be Resolved During Function Invocation?
- Does FunctionGraph Support Synchronous Transmission at the Maximum Intranet Bandwidth?
- What If the VPC Quota Is Used Up?
- How Can I Print Info, Error, or Warn Logs?
- Can I Set the Domain Name of an API to My Own Domain Name?
- Can I Change the Runtime?
- Can I Change a Function's Name?
- Why Is Message "failed to mount exist system path" Displayed?
- How Do I Obtain Uploaded Files?
- Why Can't I Receive Responses for Synchronous Invocation?
- What Should I Do If the os.system("command &") Execution Logs Are Not Collected?
- Which Directories Can Be Accessed When a Custom Runtime Is Used?
- Which Minor Versions of Python 3.6 and 3.9 Are Supported?
- Which Actions Can Be Used Instead of a VPC Administrator Agency for VPC Access?
- What Are the Possible Causes for Function Timeout?
- How Do I Obtain the Code of a Function?
- Do You Have Sample Code for Initializers?
- How Do I Enable Structured Log Query?
- Can I Enable a Listening Port in a Function to Receive External TCP Requests via EIP?
- Does FunctionGraph Support Domain Name Resolution?
- How Do I Obtain the Source IP Address of an HTTP Request Initiated by a Function?
- Function Creation FAQs
Trigger Management FAQs
- What Events Can Trigger a FunctionGraph Function?
- What If Error Code 500 Is Reported When Functions that Use APIG Triggers Return Strings?
- What Do LATEST and TRIM_HORIZON Mean in DIS Trigger Configuration?
- How Do I Use an APIG Trigger to Invoke a Function?
- How Does a Function Obtain the Request Path or Parameters When Using an APIG Trigger?
- Can I Configure a Kafka Trigger in a Different Subnet from My Function?
Dependency Management FAQs
- What Is a Dependency?
- When Do I Need a Dependency?
- What Are the Precautions for Using a Dependency?
- What Dependencies Does FunctionGraph Support?
- Does FunctionGraph Support Class Libraries?
- How Do I Use Third-Party Dependencies on FunctionGraph?
- How Do I Create Function Dependencies?
- How Do I Create a Dependency on the FunctionGraph Console?
- How Do I Add a Dependency to a Function?
Function Execution FAQs
- How Long Does It Take to Execute a FunctionGraph Function?
- Which Steps Are Included in Function Execution?
- How Does FunctionGraph Process Concurrent Requests?
- What If Function Instances Have Not Been Executed for a Long Time?
- How Can I Speed Up Initial Access to a Function?
- How Do I Know the Actual Memory Used for Function Execution?
- Why Is My First Request Slow?
- What Do I Do If an Error Occurs When Calling an API?
- How Do I Read the Request Header of a Function?
- Can the Synchronous Execution Interface Be Invoked on a Private Network?
- Why Does a Function Use More Memory Than Estimated and Even Trigger the Out of Memory Alarm?
- How Do I Check the Memory Usage When Seeing "runtime memory limit exceeded"?
- How Do I Troubleshoot "CrashLoopBackOff"?
- After I Updated an Image with the Same Name, Reserved Instances Still Use the Old Image. What Can I Do?
- Function Configuration FAQs
- External Resource Access FAQs
Other FAQs
- How Do I View the Alarm Rules Configured for a Function?
- Does FunctionGraph Support ZIP Decompiling During Video Transcoding?
- Will Resources Created During FunctionGraph 2.0 OBT Be Automatically Released When They Expire? Will Them Be Billed?
- What Is an App in FunctionGraph?
- Do I Need to Pay for Cold Start Time?
- Why Am I Seeing a Message Indicating that My Account Was Suspended When Creating a Function?
- Will the Requests of All My Functions in Different Regions Be Billed?
- Migration from FunctionGraph V1 to V2
General FAQs
More Documents
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Why Can't I Enable or Disable OBS Triggers by Calling APIs?
- Can I Create an OBS Trigger with an Existing Bucket?
- Other FAQs
General FAQs
- Before You Start
- API Overview
- Calling APIs
- Function Model Definition
Function Management Zone APIs
- Querying a Function List
- Publishing a Function Version
- Querying the Versions of a Function
- Creating an Alias for a Function Version
- Modifying the Alias Information About a Function Version
- Deleting an Alias of a Function Version
- Querying the Alias Information About a Function Version
- Querying the Version Alias List of a Function
- Querying All Triggers of a Function
- Querying the Information About a Trigger
- Deleting All Triggers of a Function
- Creating a Trigger
- Deleting a Trigger
- Function Data Zone APIs
- Appendix
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Other FAQs
General FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
- Function Metrics
- Function Logs
- Function Triggers
- Appendix
- Developer Guide (Kuala Lumpur Region)
- Videos
Developing an HTTP Function
Introduction
When developing an HTTP function using a custom image, implement an HTTP server in the image and listen on port 8000 for requests. (Do not change port 8000 in the examples provided in this section.) HTTP functions support only APIG triggers.
Step 1: Prepare the Environment
To perform the operations described in this section, ensure that you have the FunctionGraph FullAccess permissions, that is, all permissions for FunctionGraph. For more information, see Permissions Management.
Step 2: Create an Image
Take the Linux x86 64-bit OS as an example.
- Create a folder.
mkdir custom_container_http_example && cd custom_container_http_example
- Implement an HTTP server. Node.js is used as an example. For details about other languages, see Creating an HTTP Function.
Create the main.js file to introduce the Express framework, receive POST requests, print the request body as standard output, and return "Hello FunctionGraph, method POST" to the client.
const express = require('express'); const PORT = 8000; const app = express(); app.use(express.json()); app.post('/*', (req, res) => { console.log('receive', req.body); res.send('Hello FunctionGraph, method POST'); }); app.listen(PORT, () => { console.log(`Listening on http://localhost:${PORT}`); });
- Create the package.json file for npm so that it can identify the project and process project dependencies.
{ "name": "custom-container-http-example", "version": "1.0.0", "description": "An example of a custom container http function", "main": "main.js", "scripts": {}, "keywords": [], "author": "", "license": "ISC", "dependencies": { "express": "^4.17.1" } }
- name: project name
- version: project version
- main: application entry file
- dependencies: all available dependencies of the project in npm
- Create a Dockerfile.
FROM node:12.10.0 ENV HOME=/home/custom_container ENV GROUP_ID=1003 ENV GROUP_NAME=custom_container ENV USER_ID=1003 ENV USER_NAME=custom_container RUN mkdir -m 550 ${HOME} && groupadd -g ${GROUP_ID} ${GROUP_NAME} && useradd -u ${USER_ID} -g ${GROUP_ID} ${USER_NAME} COPY --chown=${USER_ID}:${GROUP_ID} main.js ${HOME} COPY --chown=${USER_ID}:${GROUP_ID} package.json ${HOME} RUN cd ${HOME} && npm install RUN chown -R ${USER_ID}:${GROUP_ID} ${HOME} RUN find ${HOME} -type d | xargs chmod 500 RUN find ${HOME} -type f | xargs chmod 500 USER ${USER_NAME} WORKDIR ${HOME} EXPOSE 8000 ENTRYPOINT ["node", "main.js"]
- FROM: Specify base image node:12.10.0. The base image is mandatory and its value can be changed.
- ENV: Set environment variables HOME (/home/custom_container), GROUP_NAME and USER_NAME (custom_container), USER_ID and GROUP_ID (1003). These environment variables are mandatory and their values can be changed.
- RUN: Use the format RUN <Command>. For example, RUN mkdir -m 550 ${HOME}, which means to create the home directory for user ${USER_NAME} during container building.
- USER: Switch to user ${USER_NAME}.
- WORKDIR: Switch the working directory to the home directory of user ${USER_NAME}.
- COPY: Copy main.js and package.json to the home directory of user ${USER_NAME} in the container.
- EXPOSE: Expose port 8000 of the container. Do not change this parameter.
- ENTRYPOINT: Run the node main.js command to start the container. Do not change this parameter.
- You can use any base image.
- In the cloud environment, UID 1003 and GID 1003 are used to start the container by default. The two IDs can be modified by choosing Configuration > Basic Settings > Container Image Override on the function details page. They cannot be root or a reserved ID.
- Do not change port 8000 in the example HTTP function.
- Build an image.
In the following example, the image name is custom_container_http_example, the tag is latest, and the period (.) indicates the directory where the Dockerfile is located. Run the image build command to pack all files in the directory and send the package to a container engine to build an image.
docker build -t custom_container_http_example:latest .
Step 3: Perform Local Verification
- Start the Docker container.
docker run -u 1003:1003 -p 8000:8000 custom_container_http_example:latest
- Open a new Command Prompt, and send a message through port 8000 to access the /invoke directory specified in the template code.
curl -XPOST -H 'Content-Type: application/json' -d '{"message":"HelloWorld"}' localhost:8000/helloworld
The following information is returned based on the module code:Hello FunctionGraph, method POST
- Check whether the following information is displayed:
receive {"message":"HelloWorld"}
Alternatively, run the docker logs command to obtain container logs.
Step 4: Upload the Image
Step 5: Create a Function
- In the left navigation pane of the management console, choose Compute > FunctionGraph. On the FunctionGraph console, choose Functions > Function List from the navigation pane.
- Click Create Function in the upper right corner and choose Container Image.
- Set the basic information.
- Function Type: Select HTTP Function.
- Function Name: Enter custom_container_http.
- Container Image: Select the image uploaded to SWR.
- Agency: Select an agency with the SWR Admin permission. If no agency is available, create one by referring to Creating an Agency.
- After the configuration is complete, click Create Function.
Step 6: Test the Function
- On the function details page, click Test. In the displayed dialog box, create a test event.
- Select apig-event-template, set Event Name to helloworld, modify the test event as follows, and click Create.
{ "body": "{\"message\": \"helloworld\"}", "requestContext": { "requestId": "11cdcdcf33949dc6d722640a13091c77", "stage": "RELEASE" }, "queryStringParameters": { "responseType": "html" }, "httpMethod": "POST", "pathParameters": {}, "headers": { "Content-Type": "application/json" }, "path": "/helloworld", "isBase64Encoded": false }
Step 7: View the Execution Result
Click Test and view the execution result on the right.
- Function Output: displays the return result of the function.
- Log Output: displays the execution logs of the function.
- Summary: displays key information of the logs.
A maximum of 2 KB logs can be displayed. For more log information, see Querying Function Logs.
Step 8: View Monitoring Metrics
On the function details page, click the Monitoring tab.
- On the Monitoring tab page, choose Metrics, and select a time range (such as 5 minutes, 15 minutes, or 1 hour) to query the function.
- The following metrics are displayed: invocations, errors, duration (including the maximum, average, and minimum durations), and throttles.
Step 9: Delete the Function
- On the function details page, choose Operation > Delete Function in the upper right corner.
- In the displayed dialog box, click OK to release resources.
