Help Center/FunctionGraph/User Guide (ME-Abu Dhabi Region)/FAQs/Function Execution FAQs/How Do I Troubleshoot "CrashLoopBackOff"?
Updated on 2023-11-21 GMT+08:00
The message "CrashLoopBackOff: The application inside the container keeps crashing" is displayed when a custom image execution failure occurs. In this case, perform the following operations:
- Analyze the causes. Figure 1 Viewing the execution result
- Verify the container image by referring to section "Deploying a Function Using a Container Image" in the FunctionGraph User Guide.
- Check whether the image uses the Linux x86 architecture. Currently, only Linux x86 images are supported.
Parent topic:Function Execution FAQs
