Help Center/ FunctionGraph/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Function Execution FAQs/ How Long Does It Take to Execute a FunctionGraph Function?
Updated on 2023-05-09 GMT+08:00
Within 900s for synchronous execution and 72 hours for asynchronous execution.
The default execution timeout is 3s. You can set the timeout (unit: s) to an integer from 3 to 259,200. If you set the timeout of a function to 3s, it will be terminated after 3s.
Parent topic: Function Execution FAQs
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
