Creating a Function Using a Template
Overview
FunctionGraph provides templates to automatically complete code, and running environment configurations when you create a function, helping you quickly build applications.
Creating a Function
- Log in to the FunctionGraph console. In the navigation pane, choose Templates.
- On the page that is displayed, select the FunctionGraph service, select the context-class-introduction template for Python 2.7, and click Configure.
The context-class-introduction template for Python 2.7 is used as an example. You can also select other templates.
- After you select a function template, the built-in code and configurations of the template are automatically loaded. The Create Function page is displayed.
- Set Function Name to context, select a created agency, retain default values for other parameters, and click Create Function.
If no agency is configured, the following message will be displayed when the function is triggered:
Failed to access other services because no temporary AK, SK, or token has been obtained. Please set an agency.
- Click Save.
Triggering a Function
- On the Code tab page of the context function, click Test in the upper right corner.
- In the Configure Test Event dialog box, select Blank Template and click Create.
- Click Test. After the test is complete, view the test result. Figure 1 Successful execution result
