Creating an Alarm Rule
After creating a function and trigger, you can monitor the invocation and running statuses of the function in real time.
Viewing Function Metrics
FunctionGraph differentiates the metrics of a function by version, allowing you to query the metrics of a specific function version.
Create an alarm rule for a function to report metrics to Cloud Eye so that you can view monitoring graphs and alarm messages on the Cloud Eye console.
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of the desired function.
- On the displayed function details page, select a function version or alias, and choose Monitoring > Metrics.
- Click Create Alarm Rule.
- Set alarm parameters and click Next, as shown in Figure 1.
- Enter a rule name and click OK.
Function Metrics
Table 1 lists the function metrics that can be monitored by Cloud Eye.
| Metric | Display Name | Description | Unit | Upper Limit | Lower Limit | Recommended Threshold | Value Type | Dimension |
| count | Invocations | Number of function invocations | Count | - | 0 | - | int | package-functionname |
| failcount | Errors | Number of invocation errors | Count | - | 0 | - | int | package-functionname |
| rejectcount | Throttles | Number of function throttles | Count | - | 0 | - | int | package-functionname |
| duration | Average Duration | Average duration of function invocation | ms | - | 0 | - | int | package-functionname |
| maxDuration | Maximum Duration | Maximum duration of function invocation | ms | - | 0 | - | int | package-functionname |
| minDuration | Minimum Duration | Minimum duration of function invocation | ms | - | 0 | - | int | package-functionname |
