Updated on 2023-11-21 GMT+08:00
Managing Triggers
Enabling or Disabling a Trigger
You can enable or disable triggers as required. Note that SMN, OBS and APIG triggers cannot be disabled and can only be deleted.
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of the desired function.
- Choose Configuration > Triggers. On the displayed page, locate the row that contains the target trigger, and click Disable or Enable.
Deleting a Trigger
You can delete triggers that will no longer be used.
- Return to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Choose Configuration > Triggers. On the displayed page, locate the row that contains the target trigger and click Delete.
Parent topic:Creating Triggers
