Notes and Constraints
Account Resource Constraints
The following table provides the quotas for account resources. For details on how to query and modify quotas, see Quotas.
| Resource | Limit | Adjustable |
| Maximum number of functions that can be created under an account | 400 | Yes |
| Maximum number of versions allowed for a function | 20 | Yes |
| Maximum number of aliases allowed for a function | 10 | Yes |
| Size of a code deployment package (in ZIP or JAR format) that can be uploaded to the FunctionGraph console | 40 MB | No. To adjust the quota, contact customer service. |
| Size of a code deployment package (in ZIP or JAR format) that can be edited inline during function API invocation | 50 MB | No. To adjust the quota, contact customer service. |
| Size of an original code deployment package allowed during function API invocation |
| Maximum size of deployment packages allowed for an account | 10 GB | No. To adjust the quota, contact customer service. |
| Number of concurrent executions per account | 100 | Yes |
| Maximum number of reserved instances that an account can create | 90 (Number of concurrent executions per account x 90%) | Yes |
| Size of all environment variables of a function | 4096 characters | Yes |
| Maximum size of code that can be displayed on the console | 20 MB | No. To adjust the quota, contact customer service. |
Function Running Resource Constraints
| Resource | Default | Adjustable |
| Ephemeral disk space (/tmp space) | 512 MB | No. To adjust the quota, contact customer service. |
| Number of file descriptors | 1024 | Yes |
| Total number of processes and threads | 1024 | Yes |
| Maximum execution duration per request | 259,200s | Yes |
| Valid payload size of invocation request body (synchronous invocation) | 6 MB | No. To adjust the quota, contact customer service. |
| Valid payload size of invocation response body (synchronous invocation) | 6 MB | No. To adjust the quota, contact customer service. |
| Valid payload size of invocation request body (asynchronous invocation) | 256 KB | No. To adjust the quota, contact customer service. |
| Size of imported resources | ≤ 50 MB ZIP file | No. To adjust the quota, contact customer service. |
| Image size per function | 10 GB | No. To adjust the quota, contact customer service. |
| Size of exported resources | ≤ 50 MB | No. To adjust the quota, contact customer service. |
| Instances per tenant | 1000 | Yes |
| Max. memory per function | 10 GB | No. To adjust the quota, contact customer service. |
| Bandwidth | Unlimited | - |
| Single log size | Unlimited | - |
| Maximum execution duration of initializer | 259,200s | Yes |
- Valid payload size of invocation response body (synchronous invocation): The returned character string or the JSON character string of the serialized response body is less than or equal to 6 MB by default. The actual data size varies depending on the backend settings of FunctionGraph. The backend determines the size of the serialized data with a byte-level deviation. The actual valid payload size is 6 MB ± 100 bytes.
- You are not advised to invoke a function whose execution time exceeds 90s on the FunctionGraph console. To invoke such a function, use asynchronous invocation.
- The valid payload size of a request body is 6 MB when a Kafka, DDS, DIS, or GaussDB(for Mongo) trigger is used and is 4 MB when an APIG trigger is used.
