Use of FunctionGraph
FunctionGraph allows you to run your code without provisioning or managing servers, while ensuring high availability and scalability. All you need to do is upload your code and set execution conditions, and FunctionGraph will take care of the rest. You pay only for what you use and you are not charged when your code is not running.
Process
Figure 1 shows the process of using functions.
- Write code, package and upload it to FunctionGraph, and add event sources such as Simple Message Notification (SMN), Object Storage Service (OBS), and API Gateway (APIG) event sources to build applications.
- Functions are triggered by RESTful API calls or event sources to achieve expected service purposes. During this process, FunctionGraph automatically schedules resources.
- View logs and metrics. Note that you will be billed based on code execution duration.
The following shows the details:
- Write code.
Write code in Node.js, Python, Java, or Go. For details, see the FunctionGraph Developer Guide.
- Upload code.
Edit code inline, upload a local ZIP or JAR file, or upload a ZIP file from OBS. For details, see Creating a Deployment Package.
- Trigger functions by API calls or cloud service events.
Functions are triggered by API calls or cloud service events. For details, see Creating Triggers.
- Implement auto scaling.
FunctionGraph implements auto scaling based on the number of requests. For details, see Notes and Constraints.
- View logs.
View run logs of function. FunctionGraph is interconnected with Log Tank Service (LTS). For details, see Logs.
- View monitoring information.
View graphical monitoring information. FunctionGraph is interconnected with Cloud Eye. For details, see Metrics.
- Check your bills.
After a function is executed, you will be billed based on the number of function execution requests and execution duration.
Introduction to Dashboard
- View your created functions/function quota, used storage/storage quota, and monthly invocations and resource usage. Figure 2 Monthly statistics
- View tenant-level metrics, including invocations, errors, duration, and throttles.
Table 1 describes the function metrics.
Table 1 Function metrics Metric
Unit
Invocations
Count
Total number of invocation requests, including invocation errors and throttled invocations. In case of asynchronous invocation, the count starts only when a function is executed in response to a request.
Duration
ms
Maximum duration: the maximum duration all functions are executed at a time within a period.
Minimum duration: the minimum duration all functions are executed at a time within a period.
Average duration: the average duration all functions are executed at a time within a period.
Errors
Count
Number of times that your functions failed with error code 200 being returned. Errors caused by function syntax or execution are also included.
Throttles
Count
Number of times that FunctionGraph throttles your functions due to the resource limit.
