Step 4: Create a Security Group
A security group consists of inbound and outbound rules to control the traffic that is allowed to flow into or out of instances (such as ECSs) in the security group. Security group rules are commonly used to allow or deny network traffic from specific sources or over specific protocols, block certain ports, and define specific access permissions for instances.
When creating an instance (for example, an ECS), you must associate it with a security group. If no security group has been created yet, a default security group will be created and associated with the instance. You can also create a security group and add inbound and outbound rules to allow specific traffic.
Security Group Templates
Several security group templates are provided for you to create a security group. A security group template has preconfigured inbound and outbound rules. You can select a template based on your service requirements. Table 1 describes the security group templates.
Template |
Direction |
Protocol/Port/Type |
Source/Destination |
Description |
Scenario |
General-purpose web server |
Inbound |
TCP: 22 (IPv4) |
0.0.0.0/0 |
Allows all IPv4 addresses to access instances in the security group over port 22 (SSH) for remotely logging in to Linux instances. |
TCP: 3389 (IPv4) |
0.0.0.0/0 |
Allows all IPv4 addresses to access instances in a security group over port 3389 (RDP) for remotely logging in to Windows instances. |
TCP: 80 (IPv4) |
0.0.0.0/0 |
Allows all IPv4 addresses to access instances in a security group over port 80 (HTTP) for visiting websites. |
TCP: 443 (IPv4) |
0.0.0.0/0 |
Allows all IPv4 addresses to access instances in a security group over port 443 (HTTPS) for visiting websites. |
ICMP: All (IPv4) |
0.0.0.0/0 |
Allows all IPv4 addresses to access instances in a security group over any port for using the ping command to test connectivity. |
All (IPv4) All (IPv6) |
Current security group |
Allows the instances in a security group to communicate with each other over a private network over any protocol and port. |
Outbound |
0.0.0.0/0 ::/0 |
Allows all traffic from the instances in the security group to external resources over any protocol and port. |
All ports open |
Inbound |
Allowing any traffic to enter and leave a security group over any port may be risky. |
0.0.0.0/0 ::/0 |
Allows any IP address to access the instances in a security group over any protocol and port. |
Outbound |
0.0.0.0/0 ::/0 |
Fast-add rule |
Inbound |
Allows the instances in a security group to communicate with each other over a private network. |
You can select protocols and ports that the inbound rule will apply to. |
Custom port and protocol |
0.0.0.0/0 |
Allows all IP addresses to access ECSs in a security group over specified ports (TCP or ICMP) for different purposes. |
Outbound |
0.0.0.0/0 ::/0 |
Allows all traffic from the instances in the security group to external resources using any protocol. |
- Click
in the upper left corner and select the desired region and project. - Click
in the upper left corner and choose Network > Virtual Private Cloud.
The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose Access Control > Security Groups.
The security group list is displayed.
- In the upper right corner, click Create Security Group.
The Create Security Group page is displayed.
- Configure the parameters as prompted.
Figure 1 Create Security Group
Table 2 Parameter description Parameter
Example Value
Name
Mandatory
Enter the security group name.
The security group name can contain a maximum of 64 characters, which may consist of letters, digits, underscores (_), hyphens (-), and periods (.). The name cannot contain spaces.
NOTE:You can change the security group name after a security group is created. It is recommended that you give each security group a different name.
sg-AB
Enterprise Project
Mandatory
When creating a security group, you can add the security group to an enabled enterprise project.
An enterprise project lets you manage cloud resources and personnel by enterprise project. The default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Template
Mandatory
Optional
Supplementary information about the security group.
The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
- Confirm the inbound and outbound rules of the template and click OK.
