Updated on 2025-11-05 GMT+08:00
Modifying an EIP Bandwidth
No matter which billing mode is used, if your EIP is not added to a shared bandwidth, it uses a dedicated bandwidth. A dedicated bandwidth can control how much data can be transferred using a single EIP.
This section describes how to increase or decrease the dedicated bandwidth size. Changing bandwidth size does not change the EIPs.
  2. Click in the upper left corner and select the desired region and project.
  3. Click in the upper left corner and choose Network > Elastic IP.
  4. Locate the target EIP and choose More > Modify Bandwidth in the Operation column.
    • If it is a pay-per-use EIP, the Modify Bandwidth page is displayed.
  5. Modify the bandwidth parameters as prompted.
  6. Click Next.
  7. Click Submit.
