Help Center/ Elastic IP/ User Guide (ME-Abu Dhabi Region)/ Shared Bandwidth/ Modifying a Shared Bandwidth
Updated on 2025-11-05 GMT+08:00
You can modify the name and size of a shared bandwidth as required.
- Click
in the upper left corner and select the desired region and project. - Click
in the upper left corner and choose Network > Elastic IP. - In the navigation pane on the left, choose Elastic IP and Bandwidth > Shared Bandwidths.
- In the shared bandwidth list, locate the row that contains the shared bandwidth you want to modify, click Modify Bandwidth in the Operation column, and modify the bandwidth settings.
- Click Next.
- Click Submit.
Parent topic: Shared Bandwidth
