Help Center/
Elastic IP/
User Guide (ME-Abu Dhabi Region)/
Shared Bandwidth/
Removing EIPs from a Shared Bandwidth
Updated on 2025-11-05 GMT+08:00
You can remove EIPs that are no longer required from a shared bandwidth if needed.
- Click
in the upper left corner and select the desired region and project. - Click
in the upper left corner and choose Network > Elastic IP. - In the navigation pane on the left, choose Elastic IP and Bandwidth > Shared Bandwidths.
- In the shared bandwidth list, locate the row that contains the bandwidth from which EIPs are to be removed, choose More > Remove Public IP Address in the Operation column, and select the EIPs to be removed in the displayed dialog box.
- Click OK.
Parent topic: Shared Bandwidth
