Creating a User and Granting ECS Permissions
Use IAM to implement fine-grained permissions control over your ECSs. With IAM, you can:
- Create IAM users for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing ECS resources.
- Grant only the permissions required for users to perform a specific task.
- Entrust an account or a cloud service to perform efficient O&M on your ECS resources.
If your account does not require individual IAM users, you can skip this section.
This section describes the procedure for granting permissions (see Process Flow).
Before assigning permissions to user groups, you should learn about system-defined policies supported by ECS and select the policies based on service requirements.
For details about system-defined policies supported by ECS, see Permissions.
Process Flow
- Create a user group and assign permissions.
Create a user group on the IAM console and assign the ECS ReadOnlyAccess permissions to the group.
- Create a user and add the user to the user group.
Create a user on the IAM console and add the user to the group created in step 1.
- Log in to the management console as the created user.
In the authorized region, perform the following operations:
- Choose Compute > Elastic Cloud Server in the service list. On the ECS console, click Create ECS in the upper right corner. If the creation attempt failed, the ECSReadOnlyAccess policy has already taken effect.
- Choose any service other than ECS in the service list. If a message appears indicating that you have insufficient permissions to access the service, the ECSReadOnlyAccess policy has already taken effect.
