Permissions Management
Updated on 2024-07-24 GMT+08:00
If you need to assign different permissions to employees in your enterprise to access your ECS resources, IAM is a good choice for fine-grained permissions management. IAM provides identity authentication, permissions management, and access control, helping you secure access to your resources.
With IAM, you can use your account to create IAM users, and assign permissions to the users to control their access to specific resources. For example, some software developers in your enterprise need to use ECS resources but should not be allowed to delete the resources or perform any other high-risk operations. In this scenario, you can create IAM users for the software developers and grant them only the permissions required for using ECS resources.
If your account does not need individual IAM users for permissions management, skip this section.
IAM is a free service. You pay only for the resources in your account. For more information about IAM, see IAM Service Overview.
ECS Permissions
By default, new IAM users do not have permissions assigned. You need to add a user to one or more groups, and attach permissions policies or roles to these groups. Users inherit permissions from the groups to which they are added and can perform specified operations on cloud services based on the permissions.
ECS is a project-level service deployed and accessed in specific physical regions. To assign ECS permissions to a user group, specify the scope as region-specific projects and select projects for the permissions to take effect. If you select All projects, the permissions will take effect for user groups in all region-specific projects. When accessing ECS, the users need to switch to a region where they have got permissions to use this service.
You can grant users permissions by using roles and policies.
  • Roles: A type of coarse-grained authorization mechanism that defines permissions related to user responsibilities. This mechanism provides only a limited number of service-level roles for authorization. When using roles to grant permissions, you also need to assign other roles which the permissions depend on to take effect. However, roles are not an ideal choice for fine-grained authorization and secure access control.
  • Policies: A fine-grained authorization strategy that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization, meeting requirements for secure access control. For example, you can grant ECS users only the permissions for managing a certain type of ECSs.
    Most policies define permissions based on APIs. For the API actions supported by ECS, see Permissions Policies and Supported Actions.
Table 1 lists all the system policies supported by ECS.
Table 1 System-defined permissions for ECS
Policy/Role Name
Type
Policy Content
ECS FullAccess
Administrator permissions for ECS. Users granted these permissions can perform all operations on ECSs, including creating, deleting, and viewing ECSs, and modifying ECS specifications.
System-defined policy
ECS FullAccess Policy Content
ECS CommonOperations
Common user permissions for ECS. Users granted these permissions can start, stop, restart, and query ECSs.
ECS CommonOperations Policy Content
ECS ReadOnlyAccess
Read-only permissions for ECS. Users granted these permissions can only view ECS data.
ECS ReadOnlyAccess Policy Content
Server Administrator
Full permissions for ECS. This role must be used together with the Tenant Guest role in the same project.
If a user needs to create, delete, or change resources of other services, the user must also be granted administrator permissions of the corresponding services in the same project.
For example, if a user needs to create a new VPC when creating an ECS, the user must also be granted permissions with the VPC Administrator role.
System role
Server Administrator Policy Content
Table 2 lists the common operations supported by each system-defined policy of ECS. Select the policies as required.
Table 2 Common operations supported by each system-defined policy
Operation
ECS FullAccess
ECS ReadOnlyAccess
Creating an ECS
Supported
Not supported
Not supported
Remotely logging in to an ECS on the management console
Supported
Supported
Not supported (VNC login not supported)
Querying an ECS list
Supported
Supported
Supported
Querying ECS details
Supported
Supported
Supported
Modifying ECS details
Supported
Not supported
Not supported
Starting an ECS
Supported
Supported
Not supported
Stopping an ECS
Supported
Supported
Not supported
Restarting an ECS
Supported
Supported
Not supported
Deleting an ECS
Supported
Not supported
Not supported
Reinstalling an ECS OS
Supported
Not supported
Not supported
Changing an ECS OS
Supported
Not supported
Not supported
Attaching a disk to an ECS
Supported
Not supported
Not supported
Detaching a disk from an ECS
Supported
Not supported
Not supported
Querying a disk list
Supported
Supported
Supported
Attaching a NIC to an ECS
Supported
Not supported
Not supported
Detaching a NIC from an ECS
Supported
Not supported
Not supported
Querying a NIC list
Supported
Supported
Supported
Adding tags to an ECS
Supported
Supported
Not supported
Modifying ECS specifications
Supported
Not supported
Not supported
Querying the ECS flavor list
Supported
Supported
Supported
Querying ECS groups
Supported
Supported
Supported
Helpful Links
        "Version": "1.1",
        "Statement": [
                        "Effect": "Allow",
                        "Action": [
                                "ecs:*:*",
                                "evs:*:get",
                                "evs:*:list",
                                "evs:volumes:create",
                                "evs:volumes:delete",
                                "evs:volumes:attach",
                                "evs:volumes:detach",
                                "evs:volumes:manage",
                                "evs:volumes:update",
                                "evs:volumes:use",
                                "evs:volumes:uploadImage",
                                "evs:snapshots:create",
                                "vpc:*:get",
                                "vpc:*:list",
                                "vpc:networks:create",
                                "vpc:networks:update",
                                "vpc:subnets:update",
                                "vpc:subnets:create",
                                "vpc:ports:*",
                                "vpc:routers:get",
                                "vpc:routers:update",
                                "vpc:securityGroups:*",
                                "vpc:securityGroupRules:*",
                                "vpc:floatingIps:*",
                                "vpc:publicIps:*",
                                "ims:images:create",
                                "ims:images:delete",
                                "ims:images:get",
                                "ims:images:list",
                                "ims:images:update",
                                "ims:images:upload"
        "Version": "1.1",
        "Statement": [
                        "Effect": "Allow",
                        "Action": [
                                "ecs:*:get*",
                                "ecs:*:list*",
                                "ecs:*:start",
                                "ecs:*:stop",
                                "ecs:*:reboot",
                                "ecs:blockDevice:use",
                                "ecs:cloudServerFpgaImages:relate",
                                "ecs:cloudServerFpgaImages:register",
                                "ecs:cloudServerFpgaImages:delete",
                                "ecs:cloudServerFpgaImags:unrelate",
                                "ecs:cloudServers:setAutoRecovery",
                                "ecs:cloudServerPasswords:reset",
                                "ecs:cloudServerPorts:modify",
                                "ecs:cloudServers:vnc",
                                "ecs:diskConfigs:use",
                                "ecs:securityGroups:use",
                                "ecs:serverGroups:manage",
                                "ecs:serverFloatingIps:use",
                                "ecs:serverKeypairs:*",
                                "ecs:serverPasswords:manage",
                                "ecs:servers:createConsole",
                                "ecs:servers:createImage",
                                "ecs:servers:setMetadata",
                                "ecs:servers:setTags",
                                "ecs:serverVolumes:use",
                                "evs:*:get*",
                                "evs:*:list*",
                                "evs:volumes:use",
                                "vpc:*:get*",
                                "vpc:*:list*",
                                "vpc:floatingIps:create",
                                "vpc:floatingIps:update",
                                "vpc:floatingIps:delete",
                                "vpc:publicIps:update",
                                "vpc:publicIps:delete",
                                "ims:images:get",
                                "ims:images:list",
                                "ims:images:upload"
        "Version": "1.1",
        "Statement": [
                        "Effect": "Allow",
                        "Action": [
                                "ecs:*:get*",
                                "ecs:*:list*",
                                "evs:*:get*",
                                "evs:*:list*",
                                "vpc:*:get*",
                                "vpc:*:list*",
                                "ims:*:get*",
                                "ims:*:list*"
    "Version": "1.1",
    "Statement": [
            "Action": [
                "ecs:*:*",
                "evs:*:get",
                "evs:*:list",
                "vpc:*:get",
                "vpc:*:list",
                "vpc:routers:get",
                "vpc:ports:*",
                "vpc:privateIps:*",
                "vpc:publicIps:*",
                "vpc:bandwidths:*",
                "vpc:firewalls:*",
                "ims:images:get",
                "ims:images:list",
                "ims:images:upload"
            "Effect": "Allow"
