Help Center/ Elastic Cloud Server/ User Guide (ME-Abu Dhabi Region)/ FAQs/ File Upload/Data Transfer/ How Can I Use SFTP to Transfer Files Between a Local Linux Computer and a Linux ECS?
Updated on 2025-12-10 GMT+08:00
You want to use SFTP to transfer files between a local Linux computer and a Linux ECS. The following uses CentOS as an example.
  1. Log in to the ECS as user root.
  2. Run the following command to check the OpenSSH version, which is expected to be 4.8p1 or later:
    ssh -V
    Information similar to the following is displayed:
    # OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
  3. Create a user group and a user (for example, user1).
    groupadd sftp
    useradd -g sftp -s /sbin/nologin user1
  4. Set a password for the user.
    passwd user1
    Figure 1 Setting a password
  5. Assign permissions to directories.
    chown root:sftp /home/user1
    chmod 755 -R /home/user1
    mkdir /home/user1/upload
    chown -R user1:sftp /home/user1/upload
    chmod -R 755 /home/user1/upload
  6. Run the following command to edit the sshd_config configuration file:
    vim /etc/ssh/sshd_config
    Comment out the following information:
    #Subsystem sftp /usr/libexec/openssh/sftp-server
    Add the following information:
    Subsystem sftp internal-sftp
    Match Group sftp
    ChrootDirectory /home/%u
    ForceCommand internal-sftp
    AllowTcpForwarding no
    X11Forwarding no
    Figure 2 sshd_config file with the added information
  7. Run the following command to restart the ECS:
    service sshd restart
    Alternatively, run the following command to restart sshd:
    systemctl restart sshd
  8. Run the following command on the local computer to set up the connection:
    sftp root@IP address
  9. Run the sftp command to check the connection.
  10. Transfer files or folders.
    To upload files or folders, run the put -r command.
    To download files or folders, run the get -r command.
