Help Center/ Elastic Cloud Server/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Login and Connection/ Why Does the System Display a Message Indicating Invalid Credentials When I Attempt to Access a Windows ECS?
Updated on 2024-06-21 GMT+08:00
Symptom
When you use a local PC running Windows to access a Windows ECS using RDP (for example, MSTSC), the system displays a message indicating that the credentials are invalid.
Solution
Perform the following steps to rectify the fault. After completing each step, try to access the ECS to check whether the fault is rectified. If the fault persists, go to the next step.
Step 1: Change Network Access Policy
Step 2: Modify Credentials Delegation
Step 3: Set the Credentials of the Local Server
Step 4: Disable Password Protected Sharing
  1. Log in to the ECS using VNC on the management console.
  2. Choose Start > Run. In the Run dialog box, enter gpedit.msc and click OK to start Local Group Policy Editor.
    Figure 1 gpedit.msc
  3. Choose Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options and click Network access: Sharing and security model for local accounts.
    Figure 2 Locating the network access policy
  4. Select Classic - local users authenticate as themselves and click OK.
    Figure 3 Changing the network access policy
  3. Choose Computer Configuration > Administrative Templates > System and locate Credentials Delegation.
    Figure 4 Locating the network access policy
  4. Double-click Allow Delegating Saved Credentials with NTLM-only Server Authentication and click OK.
    Figure 5 Allow Delegating Saved Credentials with NTLM-only Server Authentication
  5. Select Enabled and enter TERMSRV/* in the Show Contents text box. TERMSRV/* indicates the terminal server running on all computers.
    Figure 6 Enabled
  6. Refresh the group policy for the settings to take effect.
  7. Choose Start > Run. In the Run dialog box, enter gpupdate /force and press OK to update the group policy.
    Figure 7 Updating the group policy
  1. Open the control panel on the local server and choose Credential Manager > Windows Credentials.
    Figure 8 Credential Manager
  2. Check whether the credential of the target ECS is contained in the Windows credentials. If there is no credential, add one.
    • Internet or network address: IP address of the ECS
    • User name: Username for logging in to the ECS
    • Password: Password for logging in to the ECS
      Figure 9 Add a Windows Credential
  1. Log in to the ECS.
  2. Choose Start > Control Panel > All Control Panel Items > Network and Sharing Center > Change advanced sharing settings.
  3. In the Password protected sharing pane, select Turn off password protected sharing.
    Figure 10 Turn off password protected sharing
  4. Click Save changes.
