Updated on 2025-12-10 GMT+08:00
Overview
Security Group
A security group is a collection of access control rules for ECSs that have the same security protection requirements and that are mutually trusted. After a security group is created, you can create various access rules for the security group, these rules will apply to all ECSs added to this security group.
You can also customize a security group or use the default one. The system provides a default security group for you, which permits all outbound traffic and denies inbound traffic. ECSs in a security group are accessible to each other. For details about the default security group, see Default Security Groups and Rules.
  • A security group works only when the network communication is normal. If two ECSs are in the same security group but in different VPCs, the security group does not take effect. You can use a VPC peering connection to connect the two VPCs first. For details, see VPC Connectivity Options.
Security Group Rules
After a security group is created, you can add rules to the security group. A rule applies either to inbound traffic (ingress) or outbound traffic (egress). After ECSs are added to the security group, they are protected by the rules of that group.
Each security group has default rules. For details, see Default Security Groups and Rules. You can also customize security group rules. For details, see Configuring Security Group Rules.
Constraints on Using Security Groups
  • By default, you can add up to 50 security group rules to a security group.
  • By default, you can associate no more than five security groups with each cloud server or extended network interface. In such a case, the rules of all the selected security groups are combined and applied together.
  • A security group can have no more than 6,000 instances associated, or its performance will deteriorate.
  • For inbound rules of a security group, the sum of the rules with Source set to Security group, of the rules with Source set to IP address group, and of the rules with inconsecutive ports, cannot exceed 120. Excess rules will not take effect. If there are both IPv4 and IPv6 security group rules, up to 120 rules can be added for each type.
    The limits on outbound security group rules are the same as those on inbound rules.
    For example, to add inbound IPv4 rules to a security group (Sg-A), you can refer to Table 1 for rules that meet the restrictions. Of these rules, rule A02 uses inconsecutive ports (TCP: 22,25,27) and security group Sg-B as the source. In this case, only one quota is occupied.
    Table 1 Inbound security group rules
    Rule No.
    Action
    Type
    Protocol & Port
    Source
    Rule A01
    Allow
    IPv4
    All
    Current security group: Sg-A
    Rule A02
    Allow
    IPv4
    TCP: 22,25,27
    Another security group: Sg-B
    Rule A03
    Allow
    IPv4
    TCP: 80-82
    IP address group: ipGroup-A
    Rule A04
    Allow
    IPv4
    TCP: 22-24,25
    IP address: 192.168.0.0/16
