Security Group Configuration Examples
- Remotely Logging In to an ECS from a Local Server
- Remotely Connecting to an ECS from a Local Server to Upload or Download Files over FTP
- Setting Up a Website on an ECS to Provide Internet-Accessible Services
- Using ping Command to Verify Network Connectivity
- Enabling Communications Between Instances in Different Security Groups
- Allowing External Instances to Access the Database Deployed on an ECS
- Allowing ECSs to Access Only Specific External Websites
Notes
Note the following before configuring security group rules:
- Instances associated with different security groups are isolated from each other by default.
- Generally, a security group denies all external requests by default, while allowing instances in it to communicate with each other.
If required, you can add inbound rules to allow specific traffic to access the instances in the security group.
- By default, outbound security group rules allow all requests from the instances in the security group to access external resources.
If outbound rules are deleted, the instances in the security group cannot communicate with external resources. To allow outbound traffic, you need to add outbound rules by referring to Table 1.
Table 1 Default outbound rules in a security group Direction
Type
Protocol & Port
Destination
Outbound
IPv4
All
0.0.0.0/0
Allows the instances in the security group to access any IPv4 address over any port.
Outbound
IPv6
All
::/0
Allows the instances in the security group to access any IPv6 address over any port.
A security group denies all external requests by default. To remotely log in to an ECS in a security group from a local server, add an inbound rule based on the OS running on the ECS.
- To remotely log in to a Linux ECS using SSH, enable port 22. For details, see Table 2.
- To remotely log in to a Windows ECS using RDP, enable port 3389. For details, see Table 3.
Table 2 Remotely logging in to a Linux ECS using SSH Direction
Type
Protocol & Port
Source
Inbound
IPv4
TCP: 22
IP address: 0.0.0.0/0
Table 3 Remotely logging in to a Windows ECS using RDP Direction
Type
Protocol & Port
Source
Inbound
IPv4
TCP: 3389
If the source is set to 0.0.0.0/0, all external IP addresses are allowed to remotely log in to the ECS. To ensure network security and prevent service interruptions caused by network intrusions, set the source to a trusted IP address (for example, the EIP bound to an ECS). For details, see Table 4.
By default, a security group denies all external requests. If you need to remotely connect to an ECS from a local server to upload or download files over FTP, you need to enable FTP ports 20 and 21.
Direction |
Type |
Protocol & Port |
Source |
Inbound |
IPv4 |
TCP: 20-21 |
IP address: 0.0.0.0/0 |
- If the source is set to 0.0.0.0/0, all external IP addresses are allowed to remotely log in to the ECS to upload or download files. To ensure network security and prevent service interruptions caused by network intrusions, set the source to a trusted IP address. For details, see Table 6.
- You must first install the FTP server program on the ECSs and then check whether ports 20 and 21 are working properly.
A security group denies all external requests by default. If you set up a website on an ECS to allow access from the Internet, you need to add an inbound rule to the ECS security group to allow access over specific ports, such as HTTP (80) and HTTPS (443).
Direction |
Type |
Protocol & Port |
Source |
Inbound |
IPv4 |
TCP: 80 |
Inbound |
IPv4 |
TCP: 443 |
Ping works by sending an Internet Control Message Protocol (ICMP) Echo Request. To ping an ECS from your PC to verify the network connectivity, you need to add an inbound rule to the security group of the ECS to allow ICMP traffic.
Direction |
Type |
Protocol & Port |
Source |
Inbound |
IPv4 |
ICMP: All |
Inbound |
IPv6 |
ICMP: All |
IP address: ::/0 |
Instances in the same VPC but in different security groups cannot communicate with each other. If you want ECSs in security group sg-A to access MySQL databases in security group sg-B, you need to add an inbound rule to security group sg-B to allow access from ECSs in security group sg-A.
Direction |
Type |
Protocol & Port |
Source |
Inbound |
IPv4 |
TCP: 3306 |
Security group: sg-A |
- MySQL: port 3306
- Oracle: port 1521
- MS SQL: port 1433
- PostgreSQL: port 5432
- Redis: port 6379
In this example, the source is for reference only. Set the source based on actual requirements.
Direction |
Type |
Protocol & Port |
Source |
Description |
Inbound |
IPv4 |
TCP: 3306 |
Allows the ECSs in security group sg-A to access the MySQL database. |
Inbound |
IPv4 |
TCP: 1521 |
Security group: sg-B |
Allows the ECSs in security group sg-B to access the Oracle database. |
Inbound |
IPv4 |
TCP: 1433 |
IP address: 172.16.3.21/32 |
Allows the ECS whose private IP address is 172.16.3.21 to access the MS SQL database. |
Inbound |
IPv4 |
TCP: 5432 |
IP address: 192.168.0.0/24 |
Allows ECSs whose private IP addresses are in the 192.168.0.0/24 network to access the PostgreSQL database. |
Inbound |
IPv4 |
TCP: 6379 |
IP address group: ipGroup-A |
Allows ECSs whose private IP addresses are in IP address group ipGroup-A to access the Redis database. |
By default, a security group allows all outbound traffic. Table 12 lists the default outbound rules. If you want to allow ECSs to access only specific websites, configure the security group as follows:
- Add outbound rules to only allow traffic over specific ports to specific IP addresses.
Table 11 Allowing ECSs to access only specific external websites Direction
Type
Protocol & Port
Destination
Outbound
IPv4
TCP: 80
IP address: 132.15.XX.XX
Allows ECSs in the security group to access the external website at http://132.15.XX.XX:80.
Outbound
IPv4
TCP: 443
IP address: 145.117.XX.XX
Allows ECSs in the security group to access the external website at https://145.117.XX.XX:443.
- Delete the default outbound rules that allow all traffic.
Table 12 Default outbound rules in a security group Direction
Type
Protocol & Port
Destination
Outbound
IPv4
All
0.0.0.0/0
Outbound
IPv6
All
::/0
