Help Center/
Elastic Cloud Server/
User Guide (ME-Abu Dhabi Region)/
FAQs/
OS/
How Can I Install a GUI on an ECS Running CentOS 6?
Updated on 2025-12-10 GMT+08:00
To provide a pure system, the ECSs running CentOS 6 do not have a GUI installed by default. You can install a GUI on such ECSs as needed.
- Before installing a GUI on an ECS, ensure that the idle memory is greater than or equal to 2 GB. Otherwise, the GUI installation may fail or the ECS cannot be started after the installation.
Parent topic: OS
