Expanding the Capacity of an EVS Disk
You can expand the disk capacity if it is insufficient. Both system and data disks can be expanded.
- Apply for an EVS disk and attach it to an ECS.
- Expand the capacity of an existing EVS disk. The capacities of both system disks and data disks can be expanded.
You can expand the disk capacities when the EVS disks are in the In-use or Available state.
- Expanding an In-use EVS disk means expanding the capacity of an EVS disk that has been attached to an ECS. Only certain OSs support the expansion of In-use EVS disks. For details, see "Expanding an In-use EVS Disk" in Elastic Volume Service User Guide.
- Expanding an Available EVS disk means expanding the capacity of an EVS disk that has not been attached to any ECS. For details, see "Expanding an Available EVS Disk" in Elastic Volume Service User Guide.
For more details, see Expanding the Capacity of an EVS Disk in Elastic Volume Service User Guide.
After the disk capacity is expanded, only the storage capacity of the EVS disk is expanded. To use the added storage space, you also need to log in to the ECS and extend the partition and file system.
Related Operations
For a Windows ECS, if you want to expand the disk capacity by clearing disk files, you can reduce the size of the WinSxS folder using tools built into Windows. For details, see Clean Up the WinSxS Folder.
