Managing Virtual IP Addresses
A virtual IP address provides the second IP address for one or more ECS NICs, improving high availability between the ECSs.
Binding a Virtual IP Address
- Under Computing, click Elastic Cloud Server.
- On the Elastic Cloud Server page, click the name of the target ECS.
The page providing details about the ECS is displayed.
- On the Network Interfaces tab, locate the target virtual IP address and click Manage Virtual IP Address.
- On the IP Addresses tab of the displayed page, locate the row containing the target virtual IP address and select Bind to EIP or Bind to Server in the Operation column.
Multiple ECSs deployed to work in active/standby mode can be bound with a virtual IP address to improve DR performance.
- Click OK.
Logging In to the ECS to Configure Virtual IP Addresses
After you bind one or more virtual IP addresses to an ECS on the console, you must log in to the ECS to manually configure these virtual IP address.
- Linux: CentOS 7.2 64bit and Ubuntu 22.04 server 64bit
- Windows: Windows Server
- Obtain the NIC that the virtual IP address is to be bound and the connection of the NIC:
Information similar to the following is displayed:
The command output in this example is described as follows:
- eth0 in the DEVICE column indicates the NIC that the virtual IP address is to be bound.
- Wired connection 1 in the NAME column indicates the connection of the NIC.
- Add the virtual IP address for the connection:
nmcli connection modify "Connection name of the NIC" +ipv4.addresses Virtual IP address
Configure the parameters as follows:
- Connection name of the NIC: The connection name of the NIC obtained in 1. In this example, the connection name is Wired connection 1.
- Virtual IP address: Enter the virtual IP address to be added. If you add multiple virtual IP addresses at a time, separate every two with a comma (,).
Example commands:- Adding a single virtual IP address: nmcli connection modify "Wired connection 1" +ipv4.addresses 172.16.0.125
- Adding multiple virtual IP addresses: nmcli connection modify "Wired connection 1" +ipv4.addresses 172.16.0.125,172.16.0.126
- Make the configuration in 2 take effect:
nmcli connection up "Connection name of the NIC"
In this example, run the following command:
nmcli connection up "Wired connection 1"
- Check whether the virtual IP address has been bound:
Information similar to the following is displayed. In the command output, the virtual IP address 172.16.0.125 is bound to NIC eth0.
To delete an added virtual IP address, perform the following steps:
- Delete the virtual IP address from the connection of the NIC:
nmcli connection modify "Connection name of the NIC" -ipv4.addresses Virtual IP address
To delete multiple virtual IP addresses at a time, separate every two with a comma (,). Example commands are as follows:- Deleting a single virtual IP address: nmcli connection modify "Wired connection 1" -ipv4.addresses 172.16.0.125
- Deleting multiple virtual IP addresses: nmcli connection modify "Wired connection 1" -ipv4.addresses 172.16.0.125,172.16.0.126
- Make the deletion take effect by referring to 3.
Linux (Ubuntu 22.04 server 64bit is used as an example.)
- Obtain the NIC that the virtual IP address is to be bound:
Information similar to the following is displayed. In this example, the NIC bound to the virtual IP address is eth0.
root@ecs-X-ubantu:~# ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 172.16.0.210 netmask 255.255.255.0 broadcast 172.16.0.255 inet6 fe80::f816:3eff:fe01:f1c3 prefixlen 64 scopeid 0x20<link> ether fa:16:3e:01:f1:c3 txqueuelen 1000 (Ethernet) RX packets 43915 bytes 63606486 (63.6 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 3364 bytes 455617 (455.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 ... - Switch to the /etc/netplan directory:
cd /etc/netplan
- Add a virtual IP address to the NIC.
- Open the configuration file 01-netcfg.yaml:
vim 01-netcfg.yaml
- Press i to enter the editing mode.
- In the NIC configuration area, add a virtual IP address.
In this example, add a virtual IP address for eth0:
addresses:
- 172.16.0.26/32
The file content is as follows:network: version: 2 renderer: NetworkManager ethernets: eth0: dhcp4: true addresses: - 172.16.0.26/32 eth1: dhcp4: true eth2: dhcp4: true eth3: dhcp4: true eth4: dhcp4: true - Press Esc, enter :wq!, save the configuration, and exit.
- Make the configuration in 3 take effect:
netplan apply
Information similar to the following is displayed. In the command output, the virtual IP address 172.16.0.26 is bound to NIC eth0.
root@ecs-X-ubantu:/etc/netplan# ip a ... 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether fa:16:3e:01:f1:c3 brd ff:ff:ff:ff:ff:ff altname enp0s3 altname ens3 inet 172.16.0.26/32 scope global noprefixroute eth0 valid_lft forever preferred_lft forever inet 172.16.0.210/24 brd 172.16.0.255 scope global dynamic noprefixroute eth0 valid_lft 107999971sec preferred_lft 107999971sec inet6 fe80::f816:3eff:fe01:f1c3/64 scope link valid_lft forever preferred_lft forever
Windows OS (Windows Server is used as an example here.)
- In Control Panel, click Network and Sharing Center, and click the corresponding local connection.
- On the displayed page, click Properties.
- On the Network tab page, select Internet Protocol Version 4 (TCP/IPv4).
- Click Properties.
- Select Use the following IP address and set IP address to the private IP address of the ECS, for example, 10.0.0.101.
Figure 1 Configuring private IP address
- Click Advanced.
- On the IP Settings tab, click Add in the IP addresses area.
Add the virtual IP address, for example, 10.0.0.154.
Figure 2 Configuring virtual IP address
- Click OK.
- In the Start menu, open the Windows command line window and run the following command to check whether the virtual IP address has been configured:
ipconfig /all
In the command output, IPv4 Address is the virtual IP address 10.0.0.154, indicating that the virtual IP address of the ECS NIC has been correctly configured.
