On this page
Help Center/ Elastic Cloud Server/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Disk Management/ Why Does a Linux ECS with a SCSI Disk Attached Fails to Be Restarted?
Updated on 2024-04-15 GMT+08:00
Symptom
For a Linux ECS with a SCSI disk attached, if you have enabled automatic SCSI disk attachment upon ECS startup in /etc/fstab and the disk drive letter (for example, /dev/sdb) is used, the ECS fails to restart.
Possible Causes
SCSI disk allocation is determined based on the ID of the slot accommodating the disk as well as the available drive letter in the ECS. Each time you attach a disk to the ECS, an idle drive letter is automatically allocated in sequence. When the ECS starts, the disks are loaded in slot sequence. A slot ID corresponds to a drive letter.
After the SCSI disk is detached from the running ECS, the slot sequence for disks may change, leading to the disk drive letter being changed after the ECS is restarted. As a result, the slot IDs do not correspond to the drive letters, and the ECS fails to restart.
Solution
  1. Log in to the ECS as user root.
  2. Run the following command to obtain the SCSI ID according to the drive letter of the SCSI disk:
    ll /dev/disk/by-id/|grep Disk drive letter
    For example, if the drive letter of the SCSI disk is /dev/sdb, run the following command:
    ll /dev/disk/by-id/|grep sdb
    CNA64_22:/opt/galax/eucalyptus/ecs_scripts # ll /dev/disk/by-id/|grep sdb
    lrwxrwxrwx 1 root root  9 Dec  6 11:26 scsi-3688860300001436b005014f890338280 -> ../../sdb
    lrwxrwxrwx 1 root root  9 Dec  6 11:26 wwn-0x688860300001436b005014f890338280 -> ../../sdb
  3. Change the drive letter (for example, /dev/sdb) of the SCSI disk to the corresponding SCSI ID in the /etc/fstab file.
    /dev/disk/by-id/SCSI ID
    For example, if the SCSI ID obtained in step 2 is scsi-3688860300001436b005014f890338280, use the following data to replace /dev/sdb:
    /dev/disk/by-id/scsi-3688860300001436b005014f890338280
