Help Center/ Elastic Cloud Server/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Remote Login/ VNC Login/ Why Does a Blank Screen Appear After I Attempted to Log In to an ECS Using VNC?
Updated on 2025-12-10 GMT+08:00
The blank screen means that another user has logged in to this ECS using VNC, so you were logged out.
Only one user can be logged in to an ECS using VNC at a time. If you are already logged in and another user logs in to the same ECS, you will be automatically logged out.
You can log back in, but that will kick the other user out.
