Scenarios and Disk Partitions
If you have added a data disk during ECS creation, you must initialize the data disk after logging in to the ECS.
- System disk
A system disk does not require manual initialization because it is automatically created and initialized upon server creation. The default partition style is master boot record (MBR).
- Data disk
- If a data disk is created along with a server, it will be automatically attached to the server.
- If a data disk is created separately, you need to manually attach it to a server.
In both cases, you must initialize the data disk before using it. Choose an appropriate partition style based on your service plan.
Partitioning Operation Guide
Table 1 lists the common disk partition styles. In Linux, different disk partition styles require different partitioning tools.
Disk Partition Style |
Maximum Disk Capacity Supported |
Maximum Number of Partitions Supported |
Linux Partitioning Tool |
Master Boot Record (MBR) |
2 TiB |
With MBR, you can create several primary partitions and one extended partition. The extended partition must be divided into logical partitions before use. For example, if 6 partitions need to be created, you can create them in the following two ways:
GUID Partition Table (GPT) |
18 EiB 1 EiB = 1048576 TiB |
Unlimited Disk partitions created using GPT are not categorized. |
parted |
