Can I Attach Multiple Disks to an ECS?
- When you create an ECS, you can attach 24 disks to it.
- After you create an ECS, you can attach up to 60 disks to it.
Table 1 Numbers of disks that can be attached to a newly created ECS ECS Type
Maximum VBD Disks
Maximum SCSI Disks
Constraint
KVM
(excluding D3 ECSs)
24
59
VBD disks + SCSI disks ≤ 60 (This constraint does not apply to local disks.)
The number of local disks is determined based on the ECS flavor.
D3
24
30
VBD disks + SCSI disks ≤ 54 (This constraint does not apply to local disks.)
- The system disk of an ECS is of VBD type. The maximum number of SCSI disks is 59.
- For a D-series KVM ECS, its local disks use two SCSI controllers, indicating that 30 SCSI drive letters are used. A maximum of 30 SCSI disks can be attached to such an ECS.
How Can I Check Whether an ECS Is Created Before or After the Disk Function Upgrade?
- Under Computing, click Elastic Cloud Server.
- Click the name of the target ECS. The page providing details about the ECS is displayed.
- Click the Disks tab.
- Check the number of disks that can be attached to the ECS to determine the total number of disks.
- If the total number of disks that can be attached is 24 (including the system disk), the ECS is created before the disk function upgrade.
- If the total number of disks that can be attached is 60 (including the system disk), the ECS is created after the disk function upgrade.
