Help Center/
Elastic Cloud Server/
User Guide (ME-Abu Dhabi Region)/
FAQs/
Disk Partition, Attachment, and Expansion/
Will My EVS Disk Be Deleted When I Delete Its Server?
Updated on 2025-12-10 GMT+08:00
- For pay-per-use disks:
- If such disks are separately purchased and are attached, the system will prompt you whether to delete them when you delete the server. You can make the decision based on your requirements.
Parent topic: Disk Partition, Attachment, and Expansion
