(Recommended) Creating a Key Pair on the Management Console
You can use the management console to create a key pair. ECS stores the public key and you store the private key.
- Click
in the upper left corner and select your region and project. - Under Computing, click Elastic Cloud Server.
- In the navigation pane on the left, choose Key Pair.
- On the displayed page, click Create Key Pair.
- Enter a key pair name.
A key pair name consists of two parts: KeyPair and four random digits (KeyPair-xxxx).
- Click OK.
- Manually or automatically download a .pem private key file with the name that you specify as the key name. Store it in a secure place and click OK.
This is the only chance for you to save the private key file. Keep it secure. You'll need to provide the key pair name when you create an ECS, and the corresponding private key each time you connect to the ECS through SSH.
