Help Center/
Elastic Cloud Server/
User Guide (ME-Abu Dhabi Region)/
FAQs/
Passwords and Key Pairs/
Disabling SELinux
Updated on 2023-05-06 GMT+08:00
Disabling SELinux
SUSE does not have the SELinux configuration files. You can skip this section.
- Use the vi editor to open /etc/selinux/config.
vi /etc/selinux/config
- Press i to enter insert mode and set the value of SELINUX to disabled.
- Press Esc and enter :wq to save and exit the file.
Parent topic: Passwords and Key Pairs
