Methods for Improving ECS Security
Updated on 2024-06-21 GMT+08:00
If ECSs are not protected, they may be attacked by viruses, resulting in data leakage or data loss.
You can use the methods introduced below to protect your ECSs from viruses or attacks.
Protection Types
ECS can be protected externally and internally.
Table 1 Methods for improving ECS security
Type
Protection Method
External security
Trojan horses or other viruses are common external security issues. To address these issues, you can choose services such as Host Security Service (HSS) based on your service requirements:
Internal security
Weak passwords and incorrect ports opening may cause internal security issues. Improving the internal security is the key to improving the ECS security. If the internal security is not improved, external security solutions cannot effectively intercept and block various external attacks.
Enabling HSS
Host Security Service (HSS) is designed to improve the overall security for ECSs. It helps you identify and manage the assets on your servers, eliminate risks, and defend against intrusions and web page tampering. There are also advanced protection and security operations functions available to help you easily detect and handle threats.
Before using the HSS service, install the HSS agent on your ECSs first and you will be able to check the ECS security status and risks in a region on the HSS console.
Monitoring ECSs
Monitoring is key for ensuring ECS performance, reliability, and availability. Using monitored data, you can determine ECS resource utilization. The cloud platform provides Cloud Eye to help you obtain the running statuses of your ECSs. You can use Cloud Eye to automatically monitor ECSs in real time and manage alarms and notifications to keep track of ECS performance metrics.
Server monitoring includes basic monitoring, OS monitoring, and process monitoring for servers.
  • Basic monitoring
    Basic monitoring does not require the agent to be installed and automatically reports ECS metrics to Cloud Eye. Basic monitoring for KVM ECSs is performed every 5 minutes.
  • OS monitoring
    By installing the Agent on an ECS, OS monitoring provides system-wide, active, and fine-grained monitoring. OS monitoring for KVM ECSs is performed every minute.
    To enable OS monitoring for a created ECS:
    You need to manually install the agent.
    For instructions about how to install and configure the Agent, see Agent Installation and Configuration.
  • Process monitoring
    Process monitoring provides monitoring of active processes on ECSs and it requires the Agent to be installed on the ECSs to be monitored. Processes are monitored at an interval of 1 minute (for KVM ECSs).
After server monitoring is enabled, you can set ECS alarm rules to customize the monitored objects and notification policies and learn about the ECS running status at any time.
On the ECS console, click to view monitoring metrics.
Figure 1 Viewing ECS metrics
Backing Up Data Periodically
Data backup is a process of storing all or part of data in different ways to prevent data loss. The following uses Cloud Backup and Recovery (CBR) as an example. For more backup methods, see Overview.
CBR enables you to back up ECSs and disks with ease. In case of a virus attack, accidental deletion, or software or hardware fault, you can restore data to any point in the past when the data was backed up. CBR protects your services by ensuring the security and consistency of your data.
You can use the cloud server backup and cloud disk backup to back up your ECS data.
  • Cloud server backup (recommended): Use this backup method if you want to back up the data of all EVS disks (system and data disks) attached to an ECS. This prevents data inconsistency caused by the time difference in creating a backup.
  • Cloud disk backup: Use this backup method if you want to back up the data of one or more EVS disks (system or data disk) attached to an ECS. This minimizes backup costs on the basis of data security.
Enhancing the Login Password Strength
Key pair authentication is recommended because it is more secure than password-based authentication. If you select the password-based authentication, ensure that the password meets the strength requirements listed in Table 2 to prevent malicious attacks.
The system does not periodically change the ECS password. It is recommended that you change your password regularly for security.
The password must conform to the following rules:
  • The password must consist of at least 10 characters.
  • Do not use easily guessed passwords (for example, passwords in common rainbow tables or passwords with adjacent keyboard characters). The password must contain at least three of the following character types: uppercase letters, lowercase letters, digits, and special characters.
  • Do not include accounts in passwords, such as administrator, test, root, oracle, and mysql.
  • Change the password at least every 90 days.
  • Do not reuse the latest five passwords.
  • Set different passwords for different applications. Do not use the same password for multiple applications.
Table 2 Password complexity requirements
Requirement
Password
  • Consists of 8 to 26 characters.
  • Contains at least three of the following character types:
    • Uppercase letters
    • Lowercase letters
    • Digits
    • Special characters for Windows: $!@%-_=+[]:./,?
    • Special characters for Linux: !@%-_=+[]:./^,{}?
  • Cannot contain the username or the username spelled backwards.
  • Cannot contain more than two consecutive characters in the same sequence as they appear in the username. (This requirement applies only to Windows ECSs.)
  • Cannot start with a slash (/) for Windows ECSs.
Improving the Port Security
You can use security groups to protect the network security of your ECSs. A security group controls inbound and outbound traffic for your ECSs. Inbound traffic originates from the outside to the ECS, while outbound traffic originates from the ECS to the outside.
You can configure security group rules to grant access to or from specific ports. You are advised to disable high-risk ports and only enable necessary ports.
Table 3 lists common high-risk ports. You are advised to change these ports to non-high-risk ports.
Table 3 Common high-risk ports
Protocol
Port
TCP
42, 135, 137, 138, 139, 444, 445, 593, 1025, 1068, 1434, 3127, 3128, 3129, 3130, 4444, 4789, 5554, 5800, 5900, and 9996
UDP
135 to 139, 1026, 1027, 1028, 1068, 1433, 1434, 4789, 5554, and 9996
Periodically Upgrading the Operating System
After ECSs are created, you need to maintain and periodically upgrade the operating system.
