Logging In to a Linux ECS from a macOS Server
Updated on 2024-07-24 GMT+08:00
This section describes how to log in to a Linux ECS from a macOS server.
You can log in to the Linux ECS through the terminal included in the macOS.
  • Using an SSH password
    1. Open the terminal of the macOS and run the following command to log in to the ECS:
      ssh Username@EIP
  • Using an SSH key
    1. Open the terminal of the macOS and run the following command to change permissions. The following operations use private key file kp-123.pem as an example. Replace it with your actual private key file.
      chmod 400 /path/kp-123.pem
      In the preceding command, path refers to the path where the key file is saved.
    2. Run the following command to log in to the ECS:
      ssh -i /path/kp-123.pem Username@EIP
      • The username is core for a CoreOS public image.
      • The username is root for a non-CoreOS public image.
Follow-up Procedure
  • After logging in to the ECS using the SSH key, you can set a password (by using the passwd command) to log in to the ECS using VNC.
