User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
3D China Map (2019)
This section describes parameters of a 3D China map (2019).
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
- Global Style
- Map Center: location of the map center on the canvas.
- Globe Rotation: to set Scaling, Horizontal, and Vertical of the map.
- Map Color: fill color of the area blocks on the map.
- Borderline: color and width of the borderline on the map.
- Subcomponents
You can add subcomponents Flying Lines, Scatters, and Columns to a 3D China map (2019).
The operations can be performed on those subcomponents:- Adding subcomponents
In the Pattern panel, click Add Subcomponent. In the displayed menu, select a subcomponent. After the subcomponent is added, the name of the added subcomponent is displayed under Add Subcomponent, for example, fly line.
- Editing subcomponents
After clicking a subcomponent, you can edit it.
- Deleting subcomponents
To delete a subcomponent, click
Data
The following figure shows the data of a 3D China map (2019):
- Field and Mapping: The data format contains the following fields by default:
- adcode: administrative area code. This is a reserved field.
- name: name of the area displayed on the map component.
- value: value of the area displayed on the map. It determines the map color together with Max. Value, Min. Value, and No Data in Map Color under Global Style.
- Data Source Type: to select the data source of the chart. Multiple data sources are provided for you to select. You need to add data sources first. For details, see Data Connection Overview.
- Automatic Update: If you select Automatic Update and set Update Interval, the data is automatically updated based on the interval.
- View Response Result: to view the data information of the selected data source.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Flying Lines
A flying line dynamically connects two geographical locations on the map.
- Pattern
- Dotted Line: style of dotted lines.
- Height: curve height of flying lines. When the value is 1, a flying line is approximately a straight line.
- Speed: speed of flying lines
- Width: width of flares. Unit: pixel.
- Color: color of flying lines.
- Data
- Field and Mapping: The data format contains the following fields. Set the field names in the data source to which each field is mapped. If the field names are left empty, the field names are the same as those in the data source to which each field is mapped.
- from: longitude and latitude of the start point of a flying line. The longitude and latitude are separated by commas (,).
- to: longitude and latitude of the end point of a flying line. The longitude and latitude are separated by commas (,).
The data source is in JSON format. The following is an example:
[ { "from": "116.85059,31.69078", "to": "118.69629,36.20882" }, { "from": "120.89355,37.09024", "to": "116.93848,31.61597" } ]
- Interaction
Scatters
Data information about geographical locations on the map can be displayed by scatters.
- Pattern
- Size: size of scatters.
- Color: color of scatters.
- Data
- lon: longitude of a scatter.
- lat: latitude of a scatter.
- value: value of a scatter. The value and the scatter size in the style determine the scatter size together. A larger value leads to a larger scatter.
[ { "lat": 62.103883, "lon": -106.523438, "value": 51 }, { "lat": 50.064192, "lon": -74.179688, "value": 94 } ]
- Interaction
Columns
Data information about geographical locations on the map can be displayed by column.
- Pattern
Height: height of columns. Unit: pixel.
Color: color of columns.
- Data
- lon: longitude of a column.
- lat: latitude of a column.
[ { "lat": 31.8998, "lon": 102.2212 }, { "lat": 28.6542, "lon": 120.079 } ]
- Interaction
