User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
Globe (Advanced)
This section describes parameters of a globe (advanced) component.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Size and position of the component - Add Subcomponent
The subcomponents of the component include the flying line and heatmap point.
- Flying Lines
Two geographic locations on the map can be connected by dynamic flying lines. The following describes how to configure the pattern and data of flying lines.
- Click Add Subcomponent to add flying lines.
Figure 2 Adding flying lines
- Click Flying line. The page for configuring flying lines is displayed.
On the Pattern tab page, set the height, speed, width, and color of the flying lines.
Figure 3 Configuring flying line pattern of the componentOn the Data tab page, set the longitudes and latitudes of the start and end points of flying lines.
- Field and Mapping: from specifies the start point of the flying line, and to specifies the end point of the flying line.
- Automatic Update: If you select Automatic Update and set Update Interval, the dynamic data is automatically updated based on the interval.
- Heatmap point
Geographical locations on the map can be marked using heatmap points. The following describes how to configure the pattern and data of the heatmap points.
- Click Add Subcomponent to add heatmap points
Figure 4 Configuring the heatmap points of the component
- Click Heatmap point to enter the configuration page.
On the Pattern tab page, configure the height and color of the heatmap points.
Figure 5 Configuring heatmap point style of the componentOn the Data tab page, configure the latitudes, longitudes, and size of the heatmap points.
- Field and Mapping: lon specifies the longitude of the heatmap point. lat specifies the latitude of the heatmap point. value specifies the value of the heatmap point. Type specifies the type of the heatmap point.
- Flying Lines
- Global Style
- Globe Type: to select a globe type from the drop-down list. The value can be Particle, District, or Satellite.
- X Axis: to set the X axis of the globe by entering a value or dragging
- Y Axis: to set the Y axis of the globe by entering a value or dragging
- Z Axis: to set the Z axis of the globe by entering a value or dragging
- Auto-Rotation Speed: to set the auto-rotation speed of the globe by entering a value or dragging
. A larger value leads to a faster auto-rotation speed.
- Light
- Light: to show or hide light by clicking
or
- Intensity: to set the light intensity by entering a value or dragging
. A larger value leads to more intense light.
- Color: to set the light color by clicking the color editor.
- Backlight
- Backlight: to show or hide backlight by clicking
or
- Size: to set the radiation scope of the light by entering a value or dragging
. A larger value leads to a larger radiation scope.
- Z Axis: to set the light shadow of the globe by entering a value or dragging
. A smaller value leads to a larger light shadow and a larger value leads to a smaller light shadow.
- Color: to set the backlight color by clicking the color editor.
- Flying Line
- Flying Line: to show or hide flying lines by clicking
or
- Height: to set the height of the flying line by entering a value or dragging
. A larger value leads to a higher flying line.
- Speed: to set the speed of the flying line by entering a value or dragging
. A larger value leads to a faster flying speed.
- Width: to set the width of the flying line by entering a value or dragging
. A larger value leads to a thicker flying line.
- Color: to set the flying line color by clicking the color editor.
Data
The data configuration of the globe (advanced) map is similar to that of the basic 2D map. For details, see Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
