User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Help Center/
Data Lake Visualization/
User Guide (ME-Abu Dhabi Region)/
Component Guide/
Interaction/
Tab List
Tab List
This section describes parameters of a timeline component.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Tab List - Global Style
- Font: font type of the component text.
- Rows: to set the number of rows to be displayed by entering a value or clicking
- Columns: to set the number of columns to be displayed by entering a value or clicking
- Selection Type: to set a selection type from the drop-down list. The value can be Select one or Select more.
- Initial Value: to enter an initial value. The initial value is the same as the ID on the Data tab.
- If Selection Type is set to Select one and Initial Value is set to 1, the Tab1 column is highlighted.
- If Selection Type is set to Select more and Initial Value is set to 1;2, the Tab1 and Tab2 columns are both highlighted.
- Tab Configuration
- Font Size: font size of the component text.
- Font Color: font color of the component text.
- Font Width: font width of the component text.
- Background Color: to set background color of the tab list by clicking the color editor.
- Fillet Radius: to set the fillet radius of the tab list by entering a value or dragging
- Hover Background Color: to set the hover background color by clicking the color editor.
- Color of Selected Text: to set the color of the selected text in the tab list by clicking the color editor.
- Background Color of Selected Tab: to set the background color when the tab is highlighted by clicking the color editor.
- Radio Carousel: to play the option on the screen based on the carousel interval.
Data
The example data in the preceding figure is as follows:
[ { "id": "1", "label": "Tab1" }, { "id": "2", "label": "Tab2" }, { "id": "3", "label": "Tab3" } ]
- id: ID of a tab. Initial Value requires this parameter value to define a tab.
- label: label text displayed on the tab.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Interaction
