User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
Horizontal Bar Chart
This section describes parameters of a horizontal bar chart.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
- Global Style
Font: text font.
- Column Style
- Column Width: width of the column.
- Column Angle: round-corner angle of the column.
- Series Spacing: distance between series.
- Margin
- Top: spacing between the top sides of the chart and the component layer. You can enter a value or click
to adjust the spacing.
- Bottom: spacing between the bottom sides of the chart and the component. You can enter a value or click
- Left: spacing between the left sides of the chart and the component. You can enter a value or click
- Right: spacing between the right sides of the chart and the component. You can enter a value or click
- Value Tag
- Value Tag: to show or hide the value tag by clicking
or
- Font Size: font size of the value tag.
- Color: font color of the value tag.
- Font Width: font width of the value tag.
- Position: position of the value tag. The options are Top, Align right, Inside, Align left, Bottom, Inside left, Inside right, Inside top, and Inside bottom.
- X Axis
- X Axis: to show or hide the X axis by clicking
or
- Text: text style of the X axis, including Font Size, Color, Font Width, and Angle.
- Axis Label: to set the display format, maximum value, and minimum value of the X axis.
- Axis Unit: to set the unit and font color of the X axis.
- Coordinate Axis: color of the X axis.
- Grid Line: grid line color of the X axis.
Figure 2 X axis of a horizontal bar chart - X Axis: to show or hide the X axis by clicking
- Y Axis
- Y Axis: to show or hide the Y axis by clicking
or
- Label: text style of the Y axis, including Font Size, Color, Font Width, and Angle.
- Coordinate Axis: color of the Y axis.
- Grid Line: grid line color of the Y axis.
Figure 3 Y axis of a horizontal bar chart - Y Axis: to show or hide the Y axis by clicking
- Legend
- Legend: to show or hide the legend by clicking
or
- Text: text style of the legend, including Font Size, Color, and Font Width.
- Layout: position where the legend is located.
Figure 4 Legend of a horizontal bar chart - Legend: to show or hide the legend by clicking
- Message
- Message: If you click
, a message will pop up when you hover over a previewed or published component.
- Triggering Mode: to set the triggering mode of messages. The options are Coordinate Axis and Data.
- Interactive Effect: The bar effect is displayed when the prompt message is triggered.
- Color: font color of the message.
- Font Size: font size of the message.
- Font Width: font width of the message.
Figure 5 Message of a horizontal bar chart - Message: If you click
Data
- Data Source Type: to select the data source of the chart. Multiple data sources are provided for you to select. You need to add data sources first. For details, see Data Connection Overview.
- Converter: Select a converter to convert data into the data that meets the display requirements. For details, see Using a Converter.
- Data Mapping: The data format contains the following fields by default. Set the field names in the data source to which each field is mapped. If the field names are left empty, the field names are the same as those in the data source to which each field is mapped.
- x: category, corresponding to the X axis.
- y: data of series, corresponding to the Y axis.
- s: series. You can set a value of the s field to a series. Multiple series can be added.
Click
on the right of s to add a series. To delete an added series, click
on the right of the series.
Add a series as follows:
- Series Value: Enter a value of the s field. If the series value is empty, the value of the corresponding s field is used by default.
- Series Name: self-definable. If the series name is empty, the series value is used as the series name by default.
- Color: color of the column in the series.
- Stack: stack name. You can enter a user-defined name. If the same stack name is set for different series (with different s values) of the same category (with the same x value), the series data is displayed in the stack.
- Link: target link to which the web page points when a data item in component widget is clicked.
- Link Mode:
- New window: The target link opens a new browser window.
- Current page: The target link opens a window in the current browser window.
- Floating panel: The target link opens a floating window in the center of the current screen.
- Automatic Update: If you select Automatic Update and set Update Interval, the data is automatically updated based on the interval.
- Preview Result: Click Preview Result to view the information about the selected data source. You can click Update Query to manually update the component data when the data source changes.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
